Sodbury Wanted List
white90
X2 Doors push button doors must be dent/rust free
x2 outer wing outer skins prefer 300TDI> would take more than 2 if available
x2 Door skins if I can't find doors
300TDI fitted rubber mat Drivers side (hole free) the one that is fitted in 90s with no carpet
pr front wheel arch eyebrows (tear free)
255/85/16 BFG MT part worn or New
2L AFFF fire extinguisher
FIA master battery cut off with Alternator protection diode/connections
Collect a reinforced clutch release arm if someone remembers it ;)
x2 headlamp surrounds for the same person above :)
Tony,
I have a rusty NS door with a good skin that I just took of my 1991 200TDi. I will check it out and confirm later what dings, if any it has. If you think you can take the skin off and use it then its yours for free.
I also have the drivers door, again the frames gone, but the skin might be ok.
let me know if you think they are usable and i will bring them to OS. If not, just say so, i won't be offended.
Nigel
Tony,
Nigel
Oh, i forgot to add my wish list......
2 x D90 side panels with windows. Ideally genuine LR sliding windows with panels in Post Office red :D
Grind the edges????
I just prise them up with a screwdriver, drill out the pop rivets, and then just take the skins off. Its only soft ally. Do it all the time when the frames need welding up. You can then re-fit them and dress the crease back down again with a hammer and dolly.
Easy peasy........
Jon
