Sam Coombes Posted May 21, 2014 Share Posted May 21, 2014 Morning So my new Defender quite literally came with a set of these in the back; All the tyres are knackered, but the wheels seem in good nick and may come out well with a refurb. I wanted to get a set of Boost's fitted, but i'm almost falling for these. Are they Defender wheels? Would it be worth me selling and getting some boosts? Thanks Quote Link to comment Share on other sites More sharing options...
dave88sw Posted May 21, 2014 Share Posted May 21, 2014 Those are discovery wheels, i can't remember the name but they weren't used for many years. I don't think they would have the correct weight rating for a 110 as freestyles aren't rated for the 110's weight. You'll probably have to pay a bit more for boosts, but they would suit the vehicle much better as they're what would be fitted by Land Rover at the time. Hope that helps Quote Link to comment Share on other sites More sharing options...
Sam Coombes Posted May 21, 2014 Author Share Posted May 21, 2014 Cheers Dave, that's what I wanted to hear :-) eBay for them it is then, anyone know a good set of Boosts....? :-) Quote Link to comment Share on other sites More sharing options...
Pollywog Posted May 21, 2014 Share Posted May 21, 2014 They are called Castor and were fitted to 300tdi Discos. Quote Link to comment Share on other sites More sharing options...
Sam Coombes Posted May 21, 2014 Author Share Posted May 21, 2014 Thanks - worth ebaying, or more in scrap value? Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted May 21, 2014 Share Posted May 21, 2014 I just weighed a set of 4 of those in, got £38 for them. One of the worst looking wheels LR ever made in my opinion. 1 Quote Link to comment Share on other sites More sharing options...
Roverdrive Posted May 21, 2014 Share Posted May 21, 2014 The max weight for the wheel should be cast on one of the spokes on the inside of the wheel. After going through this with my 110, I can confirm that the Freestyles and original 3 spoke RRC alloys are only rated to 850kg. I have now gone for the boosts, with Maxxis 764 tyres fitted. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted May 22, 2014 Share Posted May 22, 2014 Pollywog is correct they are Castor alloys fitted to c. 95/96 Tdi Discoverys. They probably aren't rated to the full rear axle load for a 110/130 but in practice unless you run round an assault course at 3 tons they are unlikely to cause an issue but nobody could recommend you did it so I'm not. In my time as a dealer I once asked LR tech support what the weight ratings were for various genuine alloys and even they couldn't tell me! Google suggests that the max rear axle weight of a 110 is 1850kg which means if the alloys are rated to the same as the 850kg noted above you are only 150kg short. Tell fat people to sit in the front - but I would not use them on a 130 as that is 2200kg rear axle rating IIRC. Boosts were not fitted until 97 or 98 model year, the original LR alloys on earlier vehicles were Deep Dish. Be aware that old cheapish alloys with the sort of corrosion bubbling that you see on that one pictured may have issues with bead sealing if the corrosion is also around the bead. Quote Link to comment Share on other sites More sharing options...
Sam Coombes Posted May 22, 2014 Author Share Posted May 22, 2014 Thanks all - I will advertise to everyone in exchange for a forum donation, if there are no takers I will scrap them (cant be arsed with trying to remove and dispose of the tyres!) Thanks again. 1 Quote Link to comment Share on other sites More sharing options...
