pete3000 Posted June 23, 2014 Share Posted June 23, 2014 First time I had brimmed the tank on Saturday to the neck, got 2 miles home and a steady drip drip drip. had a look all the pipes and hoses were fine. Sender was fine. Leaking from area around pickup flange on top of new tank. I did crossmember a while back and fitted a Bearmach tank and all new parts and fittings. The new tanks have through holes for the screws (old tanks used to have blind holes). So when I did the job i was careful (not enough) and made sure I had the green rubber/metal washer thingy and even put a dab of hylomar on top of each screw thread. Well I drained 10 Litres of diesel off in short order and the leak stopped, as it must be below the top of the pickup flange now. Not looking forward to getting it all down again so soon, at least I used new tank fitting kit. Any one experienced this or have any better info on the cause, I'm sure i read about this before but can't find any relevant posts. Pete Quote Link to comment Share on other sites More sharing options...
ejparrott Posted June 23, 2014 Share Posted June 23, 2014 Sounds as though it's not been joined properly and the paint sealed the hole - assuming you're talking about the bolt flange fitting to the tank sheet. Have you got a photo? Quote Link to comment Share on other sites More sharing options...
Adam001 Posted June 23, 2014 Share Posted June 23, 2014 Hmm I just fitted a in tank pump to my 110 tank using nothing but the OEM cork gasket and the supplied bolts, spring washers and washers. Not filled it to the brim yet though! Quote Link to comment Share on other sites More sharing options...
pete3000 Posted June 23, 2014 Author Share Posted June 23, 2014 Sounds as though it's not been joined properly and the paint sealed the hole - assuming you're talking about the bolt flange fitting to the tank sheet. Have you got a photo? not yet, although i double checked the seal before I fitted it. The tank had been thinly painted at source so after I put the fittings on and checking I gave it two coats of chassis black, then waxoyl. Quote Link to comment Share on other sites More sharing options...
steve b Posted June 23, 2014 Share Posted June 23, 2014 Yep , your first post is correct , open holes in the 5 weld nuts on the return at the top . Its simply a matter of fitting a fibre washer under each screw ..........but ffs why not put the correct inserts in OR supply the washers as part of the tank kit , it's a small but bloody stupid failure to conform , Even a damn sticker to say use washers {rant over} Steveb Quote Link to comment Share on other sites More sharing options...
pete3000 Posted June 23, 2014 Author Share Posted June 23, 2014 someone ought to ave a word then, i used one of these kits with the green/silver washer thing http://www.island-4x4.co.uk/fuel-tank-fitting-genuine-wfe000190kit-esr2000kit-nrc7570kit-p-6638.html back to the drawing board, just hope Ralph hasn't had this annoyance as i recommended the kit for the nuts and bolt selection etc after he did his chassis change. This was the tank, http://www.island-4x4.co.uk/fuel-tank-stone-guard-8698-8689-bearmach-ntc2017bm-esr2243bm-wfe000190bm-p-8025.html purposely didn't buy blue box. Pete Quote Link to comment Share on other sites More sharing options...
western Posted June 23, 2014 Share Posted June 23, 2014 No problem for me as I didn't touch the top fitting, just used the sender unit seal & lock ring & the bolts to secure tank to chassis, it was still a right pain to fit on my own. still have the top plate seal ring if you want it. Quote Link to comment Share on other sites More sharing options...
pete3000 Posted June 23, 2014 Author Share Posted June 23, 2014 think that's the problem part Ralph, the green/silver bit, might get an old cork one and six fibre washers Quote Link to comment Share on other sites More sharing options...
JeffR Posted June 24, 2014 Share Posted June 24, 2014 someone ought to ave a word then, i used one of these kits with the green/silver washer thing http://www.island-4x4.co.uk/fuel-tank-fitting-genuine-wfe000190kit-esr2000kit-nrc7570kit-p-6638.html back to the drawing board, just hope Ralph hasn't had this annoyance as i recommended the kit for the nuts and bolt selection etc after he did his chassis change. This was the tank, http://www.island-4x4.co.uk/fuel-tank-stone-guard-8698-8689-bearmach-ntc2017bm-esr2243bm-wfe000190bm-p-8025.html purposely didn't buy blue box. Pete I fitted a Blue Box one a few year ago to a 110 V8, the nutserts in that were sealed end! Mind you the baffles stopped the sender float from moving (nice man from AA came with a gallon of petrol....), but other than the fact that the paint on it was see thro, it's never leaked (that may be because the V* drinks so much the tank is only ever full for a nano second).... Quote Link to comment Share on other sites More sharing options...
