FridgeFreezer Posted July 9, 2014 Share Posted July 9, 2014 I'm looking to pull a pair of Prakto 120L LPG tanks out of our 127, now a bit of googling suggests the tanks are self-sealing & fail-safe, as in the solenoids are "normally closed" type and the filler valve is one-way, but just to make sure I'm going to buy blanking caps / stop-ends for the connections. However, none of the LPG docs actually say what the threads on the connections are. Does anyone know off the top of their head, or have pointers to likely ones? Also, anyone wanna buy a twin-tank LPG kit for a V8? Quote Link to comment Share on other sites More sharing options...
Daan Posted July 9, 2014 Share Posted July 9, 2014 I thought those LPG tanks were the big plus point of your new truck? Never heard of the brand by the way. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 9, 2014 Author Share Posted July 9, 2014 I thought those LPG tanks were the big plus point of your new truck? Never heard of the brand by the way. Not really, they're huge, in the "living area", and we're unlikely to do enough miles to warrant it. Also they get you banned from Eurotunnel. Quote Link to comment Share on other sites More sharing options...
mickeyw Posted July 9, 2014 Share Posted July 9, 2014 The tank brand will likely be Stako. Not sure about threads though. Give Tinley Tech a call, they will know for sure. Those are F big tanks, don't think many will be able to accommodate them. However I shall enquire with a man I know who runs 4.6 Defender 6 wheelers Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 9, 2014 Author Share Posted July 9, 2014 As I said, tanks are Prakto, made in Belgium, supplied by RPi among others. Quote Link to comment Share on other sites More sharing options...
elbekko Posted July 9, 2014 Share Posted July 9, 2014 Probably M10x1. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 9, 2014 Author Share Posted July 9, 2014 Probably M10x1. They're definitely bigger than that, one is close to 3/8" BSP sort of size, the other is close to 1/2" BSP sort of size. However, being made in Europe and being gas fitting I'm not so sure they would be regular BSP. Quote Link to comment Share on other sites More sharing options...
elbekko Posted July 9, 2014 Share Posted July 9, 2014 Ah. Yeah, I wasn't sure, but most LPG type stuff are standard gas fittings. The thread on the filler is (1/2"?)BSP, so I wouldn't be surprised it other big fittings are too. The M10/M12 stuff is more for the high-pressure lines. Your best bet is to take some pictures and ask on lpgforum.co.uk, very helpful guys there. But the internet is right, you shouldn't need the blanking caps. Quite a bit of gas (volume-wise, not actually that much gas) will come out of the filler when you loose that. Easiest thing to do there is take a long screwdriver, put on some welding gloves, and poke it in the filler to empty it out. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 9, 2014 Share Posted July 9, 2014 If full, don't even think about trying to move them..... The gas slips around and slips a disc in your back in a heartbeat. Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 9, 2014 Author Share Posted July 9, 2014 Luckily they're dead empty, previous owner planned to remove them so ran it right out, and gave it a go every time out just to make sure. Quote Link to comment Share on other sites More sharing options...
elbekko Posted July 9, 2014 Share Posted July 9, 2014 Eh, if they're empty anyway, definitely no need to worry. Quote Link to comment Share on other sites More sharing options...
Daan Posted July 9, 2014 Share Posted July 9, 2014 Not really, they're huge, in the "living area", and we're unlikely to do enough miles to warrant it. Also they get you banned from Eurotunnel. Are there still ferys going? Leave one in, would be my advice. I can see the argument if you were to pay for the install, but if it is there, leave it. bedtime reading: http://www.mylpg.eu/lpg-prices-across-europe Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 9, 2014 Author Share Posted July 9, 2014 Are there still ferys going? Leave one in, would be my advice. That wasn't really my question - they're coming out. If you want them on your truck, I'll do you a very good price, but I have no need/use/want for them taking up ~250 litres of storage space in the back of my truck. Quote Link to comment Share on other sites More sharing options...
zoltan Posted July 15, 2014 Share Posted July 15, 2014 Can you run a tape measure over them Fridge? I may be interested for my Gaz Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 15, 2014 Author Share Posted July 15, 2014 Can you run a tape measure over them Fridge? I may be interested for my Gaz Certainly can, I'll get on it ASAP as they are now taking up space in the garden! Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted July 15, 2014 Author Share Posted July 15, 2014 Right, the big ones (fill valve) were 3/8" NPT, the solenoids were 1/4" BSP (although I believe NPT is close enough it'd fit), in the end plenty of PTFE tape should make double triple sure what little gas there is stays put. Zoltan: Tanks are about 1050mm long, 400mm diameter plus the filler plate bit. Both tanks have gauges, one has a feed for an electrical fuel gauge too. Quote Link to comment Share on other sites More sharing options...
