FridgeFreezer Posted May 15, 2020 Share Posted May 15, 2020 2 hours ago, ThreePointFive said: And now the fuel pump won't prime. It's not the relay as sticking an earth on the right pin makes the pump work. It's the forking ECU. Does the ECU work as expected on the stim? Divide and conquer - rule things in or out one at a time. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted May 15, 2020 Share Posted May 15, 2020 Also, as long as coils and edis has power, and the crank trigger is the right way round, you will get spark. Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted May 15, 2020 Author Share Posted May 15, 2020 Thanks both. For the moment I don't have the mental capacity to try to get spark while the fuel pump isn't chooching so going to focus on that. Stim fools the ECU to show the fuel pump working, I assume it can only do that by sending the signal through the right pin so my ECU can't be fully hooped if that's the case? Going to go at it fresh tomorrow. Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted May 16, 2020 Author Share Posted May 16, 2020 Stumped. The relay works if I switch it around to be the main relay. The fuel pump works if I just give it power without the relay. There is power getting to the D37 plug pin. The ECU clearly can still give a fuel pump working signal. This has to be an ECU issue, doesn't it? There is nothing physically wrong with the wiring if the pump works when powered, so I don't see how it can be anything else. Quote Link to comment Share on other sites More sharing options...
ThreePointFive Posted May 16, 2020 Author Share Posted May 16, 2020 Really Mildly miffed off with the ECU now so I am going to look at the spark situation so I get something productive done. This was my working for which one goes where, please try to find fault with this. It takes a little bit of lateral thinking but I can't prove myself wrong so I don't think this is the problem. The 4.0 GEMS coils connect to a plug that looks like this (with the two coils they each control in red based on the information below): This is the RAVE diagram as Elbekko provided on page one of this thread: To translate that to MS, you take the EDIS plug and look at the coils each pin controls: Which relates to these cylinders: So you end up with these numbers: EDIS pin 8 -> GEMS pin 1 EDIS pin 9 -> GEMS pin 4 EDIS pin 11 -> GEMS pin 2 EDIS pin 12 -> GEMS pin And you get those pins from the wiring colours, which I have done. So unless my GEMS plug was wired incorrectly by the factory, the WU/WB/WY/WK wiring colours should tell me exactly which is which. I know I'm asking a lot of effort for no one else's gain in all this. Quote Link to comment Share on other sites More sharing options...
elbekko Posted May 16, 2020 Share Posted May 16, 2020 Just to double check your connector, from RAVE: Where you have: 1 - 1 & 6, White/Black 2 - 4 & 7, White/Yellow 3 - 2 & 3, White/Blue 4 - 5 & 8, White/Pink 5 - switched 12v, White Looks like this view is of the harness side, not the coil side, so pay attention to that! The diagram you posted also has wire colours on the coil side, for reference: Just to make sure, EDIS switches ground and not +ve, right? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 17, 2020 Share Posted May 17, 2020 Yes, EDIS switches ground of the coils. @ThreePointFive if you're getting fed up, post me your ECU and I'll have a look and/or post you a spare one. 99% of the time if it works on the stim it's good, but it's juuust possible through some minor fault or previous wiring trauma it has enough chooch to light the LED on the stim but not power a relay or whatnot. Quote Link to comment Share on other sites More sharing options...
