Drivers door seal
Hi all looking for some help - sugestions.
I totally rebuilt my Defender just over 3 years ago and my driver’s door has never closed and sealed as it should.
It fits perfectly well all along and down the handle side and from top to bottom hinge and all lines up perfect.
From top hinge or just above the curve it starts to kick out all the way up to the top of the window frame.
It does touch the door seal but it sits proud of the window frame by about 10mm and is not hard on the seal.
I did try to re-shim the top hinge to see if that would work but it never made much difference.
When I built it I fitted new door skins don’t know if that made any odds.
Looks like the door is twisted and did think of just winding the window down and trying some brute force.
What do you think?
