need4speed Posted June 16, 2015 Share Posted June 16, 2015 What are the most powerful recommended bulbs fitted to these? Quote Link to comment Share on other sites More sharing options...
simonr Posted June 16, 2015 Share Posted June 16, 2015 If you search for 12v 50mm projector lamps - they are available up to 300w. The higher power ones are a bit sensitive to vibration - but I ran 150w for a while without a problem. Si Quote Link to comment Share on other sites More sharing options...
need4speed Posted June 16, 2015 Author Share Posted June 16, 2015 Ooh 4 of those would be handy. Cheers Simon Quote Link to comment Share on other sites More sharing options...
need4speed Posted June 16, 2015 Author Share Posted June 16, 2015 Will this be on the edge of what a normal 40A relay can take or will I be fine? Quote Link to comment Share on other sites More sharing options...
JeffR Posted June 16, 2015 Share Posted June 16, 2015 Be careful of "cheap" projector lamps - stick to either Osram, GEC or Philips. I use 100 W bulbs in a fibre optic light on a microscope and the cheap ones only last a couple of days whereas the decent ones can last months. Quote Link to comment Share on other sites More sharing options...
need4speed Posted June 16, 2015 Author Share Posted June 16, 2015 Maybe il use this to be on the safe side http://www.autoelectricsupplies.co.uk/product/171/category/36 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted June 16, 2015 Share Posted June 16, 2015 If you're switching them all on with one relay, 600W = 50A, so yes, either split it between two relays or one big 70A will be fine Quote Link to comment Share on other sites More sharing options...
need4speed Posted June 16, 2015 Author Share Posted June 16, 2015 Thanks mate Quote Link to comment Share on other sites More sharing options...
need4speed Posted June 16, 2015 Author Share Posted June 16, 2015 Be careful of "cheap" projector lamps - stick to either Osram, GEC or Philips. I use 100 W bulbs in a fibre optic light on a microscope and the cheap ones only last a couple of days whereas the decent ones can last months. Cheers Jeff. Yes I will buy decent ones. I know Osram used to be very good indeed. Quote Link to comment Share on other sites More sharing options...
simonr Posted June 16, 2015 Share Posted June 16, 2015 Mine are Phillips! Si Quote Link to comment Share on other sites More sharing options...
elbekko Posted June 17, 2015 Share Posted June 17, 2015 Will the X-Lite wiring and socket handle 300W? I remember mine being a bit on the small side. Quote Link to comment Share on other sites More sharing options...
simonr Posted June 17, 2015 Share Posted June 17, 2015 Fair point! It didn't do anything bad at 150W - but it definately got warm. Maybe best not to go above 150W Si Quote Link to comment Share on other sites More sharing options...
