IanT90 Posted June 13, 2016 Share Posted June 13, 2016 Had an on going problem my oil pressure warning light keeps flickering intermittently and sometimes stays off. Seems to be more of a problem after start up than when the engine is warm. Checked oil level that's fine, also fitted new oil pressure switch so not that. Even replaced spade end connection to switch as the old one was loose. Any ideas it's a 300tdi engine. Quote Link to comment Share on other sites More sharing options...
vulcan bomber Posted June 13, 2016 Share Posted June 13, 2016 Has it had an oil change recently? Quote Link to comment Share on other sites More sharing options...
Landy-Novice Posted June 13, 2016 Share Posted June 13, 2016 and if so, corrct oil grade used? ideally 10-40semi. is engine high milage/tired? Quote Link to comment Share on other sites More sharing options...
IanT90 Posted June 13, 2016 Author Share Posted June 13, 2016 Funny enough due for a service and when I checked oil level it was on low side, I only had some 10 40 available so topped up with a litre of that till I get around to doing service and oil change. Quote Link to comment Share on other sites More sharing options...
western Posted June 13, 2016 Share Posted June 13, 2016 try a new good brand filter, I had a britpart oil filter, swapped it recently for a Mahle oil filter. my oil light doesn't flicker as much now as it used too, engine is 200tdi, 24 years old & monster mileage. Quote Link to comment Share on other sites More sharing options...
IanT90 Posted June 13, 2016 Author Share Posted June 13, 2016 Last one I fitted was a Bermach been fine upto couple months ago. Registered mileage is 140k but can't confirm that's correct. I will carry out full service asap see if that helps sort it. Had couple of conflicting suggestions regsrds the correct grade of oil to use. What's the general consensus based on a well worn engine ? Quote Link to comment Share on other sites More sharing options...
IanT90 Posted June 13, 2016 Author Share Posted June 13, 2016 Which semi synthetic is best to use 10/40 or 15/40 ? Quote Link to comment Share on other sites More sharing options...
Lewis Posted June 13, 2016 Share Posted June 13, 2016 20w50, if not 15w40 I wouldn't go thinner Quote Link to comment Share on other sites More sharing options...
western Posted June 13, 2016 Share Posted June 13, 2016 mine gets 15w/40 or 20w/50. I don't bother with synth oils, just normal multigrade mineral. Quote Link to comment Share on other sites More sharing options...
IanT90 Posted June 13, 2016 Author Share Posted June 13, 2016 Thanks much appreciated probably go for 15/40 plenty of cheaper options out there for that grade Quote Link to comment Share on other sites More sharing options...
Boydie Posted June 14, 2016 Share Posted June 14, 2016 Any synthetic oil is wasted on a 300Tdi, sure you can use it but its akin to feeding pearls to swine, just go for a good quality Diesel 15w/40 grade mineral oil, Castrol, Mobil etc. use genuine Land Rover or Mahle filters and change it regularly every 10,000 kilometers or 6000 miles. Quote Link to comment Share on other sites More sharing options...
