mad_pete 92 Posted October 8, 2016 All, anyone have guidance on how to purchase magnacore leads for squirted V8 with coil packs at front. Do I have to measure current ones and go custom or is their a pack that fits please? Quote Share this post Link to post Share on other sites
Hybrid_From_Hell 248 Posted October 9, 2016 Yup ! Go to : http://www.magnecor.co.uk/custom_sets.asp KV85 are probably what you'll wnat.and they will even match yer trucks colour You need to then fill in the form and email it to them If you have the ford type coil packs you had off me these are "Generation 1" Units for the coil plug ends. High temp plug boots are worth going for too Phil is the chap who makes them / MD Nige distributorelss2011pdf.pdf Quote Share this post Link to post Share on other sites
FridgeFreezer 1,139 Posted October 11, 2016 Or you could buy a length of cable & some ends from Nige and make your own for presumably a fraction of the cost, surely Nige? Quote Share this post Link to post Share on other sites
Hybrid_From_Hell 248 Posted October 11, 2016 Yes But I didn't wnat to be accused of spammy posts I have these in stock www.megasquirt-v8.co.uk Mine are £29.50 set V8 Magnecor will be about £150 set for a V* ! Magnecor are a bit nicer but jeeeez...£££s ! Nige Quote Share this post Link to post Share on other sites
FridgeFreezer 1,139 Posted October 13, 2016 I got mine one the 109 custom-made by some other lot called Highway or something, also cost about half what Magnecore wanted, mind you the set on the ambulance were made up from Nige's kit and have worked fine for at least 10k and counting... Quote Share this post Link to post Share on other sites
Bowie69 780 Posted October 13, 2016 Fastlane auto also make good lead sets up for you, to spec: http://www.fastlaneauto.co.uk/ Quote Share this post Link to post Share on other sites
mad_pete 92 Posted October 13, 2016 I had a look on Nige's website and didn't see the leads, although I thought I got my current leads from there. Which section are they under please? Quote Share this post Link to post Share on other sites
Bowie69 780 Posted October 13, 2016 http://www.megasquirt-v8.co.uk/ms_optional.php 'DIY V8 Ignition lead set' Quote Share this post Link to post Share on other sites
FridgeFreezer 1,139 Posted October 13, 2016 Fastlane were the guys I used, well remembered Bowie! Quote Share this post Link to post Share on other sites
Daragh 2 Posted February 7 Hi guy. I am looking to source a new set of HT leads. I have a set of Nigle's DIY ones currently but seem to have botched them up and now I can only get a resistance reading on 4 of the 8! and one boot is damaged. Anyway, I remembered reading a post by Nigle (Hybrid from hell) some time ago providing details of the spec I should ask for but for the life of me I cannot find the post. If memory serves it was in the form of a completed magnacor form as per above. I'm pretty sure I even copied and pasted it somewhere to keep it safe in case I needed it .....but obviously I can't find that either. Could anyone have the spec I need? Also, I did look up the above Fastlane but can't find them on the inter web so if anybody has a link or a cheaper place to source than Magnacor I would very much appreciate it. (If relevant my spec is: RRV8 3.5 on MS1 with ford coil packs from Nigle) Thanks guys Quote Share this post Link to post Share on other sites
Bowie69 780 Posted February 7 Post: Fastlane Auto: http://www.fla-manufacturing.com/ Quote Share this post Link to post Share on other sites
Daragh 2 Posted February 8 Thanks, that is brilliant. I guess you are very happy with results or you wouldn't reconditioned them. Do yoy remember if you had the specifications or did you just tell them what it was for and the did the rest? Cheers Quote Share this post Link to post Share on other sites
Bowie69 780 Posted February 8 I didn't buy them, Magnecore are a huge amount of money, Fast Lane Auto was half the price and just as nicely made. Quote Share this post Link to post Share on other sites
Daragh 2 Posted February 8 Oh ok. I agree about price so thanks for alternative option. I will contact them and see. I'm sure if I give them the info they will know best spec. Tks a mil for help. Quote Share this post Link to post Share on other sites
FridgeFreezer 1,139 Posted February 8 You know you can just get more wire & ends from Nige, right? Quote Share this post Link to post Share on other sites
zardos 21 Posted February 8 I have a copy of my magnecor spec I used for my 3.9 Disco 1 engine but with the coils in a non standard location (because Nige's bracket would not fit with a second alternator, so mine are mounted above the driver's side rocket cover) Quote Share this post Link to post Share on other sites
Daragh 2 Posted February 8 Good evening, Yes Fridge, I could get more from Nigel but I have suspicion that maybe I did something wrong or broke them while putting them together. I have four our of 8 showing no resistance figures on multimeter ( the other four are showing circa 0.6k ohms per cm). I am up and running but tuning is a problem with crazy lambda and thus crazy VEAL moves to richer when I know it is already too rich. I am getting contradictory information from compression tests, exhaust manifold temp and and spark plug condition so after checking and finding no resistance I thought I could fix basics that I can cross off list (new sparks already in and coils seem fine). Anyway, perseverance proved successful and I found another post with Nigles info at last, so I thought I might put it up here for anyone else searching. Now that I have the spec I will contact Fla and get a cheaper alternative. Thanks for input. Quote Share this post Link to post Share on other sites
