Jocklandjohn Posted August 29, 2017 Author Share Posted August 29, 2017 Just now, Mo Murphy said: I bought 2 OEM lift pumps direct from the manufacturers website last year, one to fit as replacement and a spare. I discovered at the weekend that I need the spare 🙁 Mo Proper LR ones Mo? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 29, 2017 Share Posted August 29, 2017 No John I'm not that flush, I can't remember who from, I need to find the spare. I looked to see who the manufacturer was and then went to their own website. I starting to think that genuine is looking an attractive buy despite its price ! Mo Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted August 29, 2017 Author Share Posted August 29, 2017 If they were LR I'd be surprised! They're about £200 each! No idea what that gets you - hopefully longevity & reliability! Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 29, 2017 Share Posted August 29, 2017 £234.54 ! Ye Gods ! Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted August 29, 2017 Author Share Posted August 29, 2017 There are a few Genuine Part LR ones on Ebay for £45 if you want one, they're "new old stock" so end of line, discontinued or bankrupt stock apparently, but if they are 'old' and the membrane is perishable one might wonder at how long they might last. Mind you given that 'new' ones last less than 6 months it might be worth a punt! Here Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 29, 2017 Share Posted August 29, 2017 I had a genuine one (mine sprung a leak on a Saturday away from home and I had no choice but to use a dealer). It was £125 back then. It lasted 2ish years. Don't waste your money. Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted August 29, 2017 Author Share Posted August 29, 2017 I wasn't intending to! Delphi at £35 is enough for me thank you! Quote Link to comment Share on other sites More sharing options...
Ex Member Posted August 29, 2017 Share Posted August 29, 2017 Do you have a sedimenter? Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted August 29, 2017 Author Share Posted August 29, 2017 19 minutes ago, Red90 said: Do you have a sedimenter? I have the normal in-line LR fuel filter on the bulkhead, which is between lift pump and FIP. Are you referring to an in-line filter to put before the lift pump? I seem to recall you mentioning these in a previous post if I recall correctly? Quote Link to comment Share on other sites More sharing options...
Ex Member Posted August 30, 2017 Share Posted August 30, 2017 Yes, you want a sedimenter between the tank and lift pump. These were installed in all pre-200TDI trucks and they seem to save the lift pumps. The 200TDIs are especially prone as any dirt kills the pumps. The 300TDI is not as bad as it has a built in suction screen. NRC9708 is the LR part and its is quite cheap. There are many aftermarket options as well. Quote Link to comment Share on other sites More sharing options...
Jocklandjohn Posted August 30, 2017 Author Share Posted August 30, 2017 4 hours ago, Red90 said: Yes, you want a sedimenter between the tank and lift pump. These were installed in all pre-200TDI trucks and they seem to save the lift pumps. The 200TDIs are especially prone as any dirt kills the pumps. The 300TDI is not as bad as it has a built in suction screen. NRC9708 is the LR part and its is quite cheap. There are many aftermarket options as well. Ok Red thanks for that - it's on the shopping list! Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 30, 2017 Share Posted August 30, 2017 5 hours ago, Red90 said: Yes, you want a sedimenter between the tank and lift pump. These were installed in all pre-200TDI trucks and they seem to save the lift pumps. The 200TDIs are especially prone as any dirt kills the pumps. The 300TDI is not as bad as it has a built in suction screen. NRC9708 is the LR part and its is quite cheap. There are many aftermarket options as well. The 300 lift pump has a built in screen ? If so then surely it's better to fit a 300 lift pump to the 200 ? I imagine the mounting will be the same just different pipe fittings. Mo Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 30, 2017 Share Posted August 30, 2017 5 hours ago, Red90 said: These were installed in all pre-200TDI trucks and they seem to save the lift pumps. I dont think they were. I know of a few turbo diesels that didnt have them fitted from the factory. Quote Link to comment Share on other sites More sharing options...
western Posted August 30, 2017 Share Posted August 30, 2017 My 110 which was a UK market TD never had a sedimentor fitted from new, IIRC only export vehicle have them up until Td5 came out & that has one in rear wheel arch. Quote Link to comment Share on other sites More sharing options...
monkie Posted August 30, 2017 Share Posted August 30, 2017 My 110 TD has never had one either - I thought that it was the military land rovers fitted with 2.5 NA that had them....? Quote Link to comment Share on other sites More sharing options...
Ex Member Posted August 31, 2017 Share Posted August 31, 2017 18 hours ago, Mo Murphy said: The 300 lift pump has a built in screen ? If so then surely it's better to fit a 300 lift pump to the 200 ? I imagine the mounting will be the same just different pipe fittings. Mo Maybe. I've never looked at it. You do need a proper Delphi one as the aftermarket ones don't have the screen. It takes very little to plug the check valve. IMO, a sedimenter is a good idea for everything. They don't cost much. Quote Link to comment Share on other sites More sharing options...
