mad_pete Posted May 25, 2015 Share Posted May 25, 2015 Is it possible to change the diff lock switch without pulling the center tunnel out ? Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted May 25, 2015 Share Posted May 25, 2015 I would have thought you could do it through the centre seat box hole. Mo Quote Link to comment Share on other sites More sharing options...
Lewis Posted May 25, 2015 Share Posted May 25, 2015 I haven't checked but I doubt you could change it through the centre seatbox hole - I've swapped transfer boxes today and could only just reach the diff lock wiring with the tips of my fingers down the side of the front output housing Quote Link to comment Share on other sites More sharing options...
western Posted May 25, 2015 Share Posted May 25, 2015 Gearbox tunnel & drivers floor plate has to be removed for access & visibility Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted May 25, 2015 Share Posted May 25, 2015 Agreed Lewis but I was thinking long socket if it would fit over the switch part. Mo Quote Link to comment Share on other sites More sharing options...
Maverik Posted May 26, 2015 Share Posted May 26, 2015 Agreed Lewis but I was thinking long socket if it would fit over the switch part. Mo A long socket will just fit over the switch , but you bend the terminal inwards when you do this, which isn't that healthy for the switch... so its ok to take an old one out this way... I think I did find a switch that slotted into the socket without this happening, will have to check my records. Quote Link to comment Share on other sites More sharing options...
Dave W Posted May 26, 2015 Share Posted May 26, 2015 It is possible but it's a real PITA. You can get a ring spanner over it and move it around 1/4 of a turn at a time, i think that's why, on a TD5, they used a very small connector on the wiring for the diff lock switch whereas the hi-lo switch has a normal connector that won't fit through a ring spanner. I found when I did mine that it had to be done from below the vehicle, reaching around the transfer box output housing. I couldn't get to it from above. I also removed the difflock lever connection to give better access for a spanner. Quote Link to comment Share on other sites More sharing options...
Lewis Posted May 26, 2015 Share Posted May 26, 2015 I would guess that it's more accessible with the lt85/r380 tunnel than the lt77 tunnel Quote Link to comment Share on other sites More sharing options...
mad_pete Posted May 26, 2015 Author Share Posted May 26, 2015 Cool I have the lt85 tunnel I'll crawl around and see if I get lucky Quote Link to comment Share on other sites More sharing options...
