reb78 Posted August 22, 2016 Share Posted August 22, 2016 As above, my gearbox is currently out for repair. I thought my clutch had done fewer miles, but looking back at my service sheet, it has covered 40k. Would you replace it now? It'll add another £70-£80 onto the cost of the gearbox job, but could save the need to drop it again in the future.... hmmmmmmmmm Quote Link to comment Share on other sites More sharing options...
Fatboy Posted August 22, 2016 Share Posted August 22, 2016 I'd definitely do the clutch release fork and probably the bearing... Have a look at the friction plate and springs and see if there is any wear / damage. Quote Link to comment Share on other sites More sharing options...
martyn668 Posted August 22, 2016 Share Posted August 22, 2016 Further to Fatboy's post, I think some of the clutch release forks were pressed steel and known to fail. There is a better (forged?) part. Quote Link to comment Share on other sites More sharing options...
stephencdavies Posted August 22, 2016 Share Posted August 22, 2016 I'd change the lot. inc a heavy duty release arm.failing that i'd weld a plate behind where the rod sits. no point in going back in there if you have a choice. the truck i bought for a rebuild project had a recent clutch, but for the sake of £100 or so, it was worth swapping it out. at least it resets your usage clock. Quote Link to comment Share on other sites More sharing options...
reb78 Posted August 22, 2016 Author Share Posted August 22, 2016 So far i think my gearbox has been off every four years for some kind of issue, so the clutch has never had time to wear out! Fingers crossed that after repair its in there for longer - 10 years at least would be a nice period to not have to lift that heavy hunk of metal again with about 80k on the clutch! Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted August 22, 2016 Share Posted August 22, 2016 Personally, I'd change it Rich and the arm because you know that if you don't ... Mo ? Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted August 22, 2016 Share Posted August 22, 2016 If you hate it that much, change it Quote Link to comment Share on other sites More sharing options...
Maverik Posted August 23, 2016 Share Posted August 23, 2016 When I swapped out my engine the year before last I'd got about 30k on the clutch, on measuring it had lost very little material, but I replaced anyway, its just one of these jobs that's a ball ache to sort so you want the thing to outlast hopefully the maintenance interval of everything else. Quote Link to comment Share on other sites More sharing options...
AMB Posted August 23, 2016 Share Posted August 23, 2016 I'd change it - HD clutch, forged clutch release fork and bearing. Hard won experience has taught me that you have to take the opportunity to maintain while you can. Quote Link to comment Share on other sites More sharing options...
