FridgeFreezer Posted May 4, 2010 Share Posted May 4, 2010 This came to me as a scrap unit for spares, I believe it had been sent to Bill to see why it didn't work properly. Pictures don't do it full justice. No I didn't power it up to test it Quote Link to comment Share on other sites More sharing options...
landmannnn Posted May 4, 2010 Share Posted May 4, 2010 You should see my welding......... Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted May 4, 2010 Share Posted May 4, 2010 Available from "Incredile Hulk PCB Bogerooos Ltd" FFS even I could do better than that and won't Nige Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 4, 2010 Share Posted May 4, 2010 I could do better when I was 10! Quote Link to comment Share on other sites More sharing options...
V8 Freak Posted May 4, 2010 Share Posted May 4, 2010 Looks perfik John... They have borrowed some of Niges solder I see... I like the variation in resistor size.... Maybe the bigger ones are special for Land Rovers like innit... At least we know the person has a "Have a go" attitude. I think I spotted what may be a dry joint... Neil Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted May 4, 2010 Author Share Posted May 4, 2010 I quite enjoyed the ~12mm hole drilled through the board & heatsink for the wires to run through Quote Link to comment Share on other sites More sharing options...
roguevogue Posted May 5, 2010 Share Posted May 5, 2010 I don't see the problem, looks just like mine..............not! I'm sure he's really good with flower arranging and stuff. A fine example of why I let someone else build mine. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted May 5, 2010 Share Posted May 5, 2010 I'm sure he's really good with flower arranging and stuff. A fine example of why I let someone else build mine. So I should come to you when I need some flowers arranged Quote Link to comment Share on other sites More sharing options...
roguevogue Posted May 5, 2010 Share Posted May 5, 2010 So I should come to you when I need some flowers arranged Flower arranging, pretty good at crochet as well. Quote Link to comment Share on other sites More sharing options...
TheRecklessEngineer Posted May 5, 2010 Share Posted May 5, 2010 Has someone nicked my ECU?! Quote Link to comment Share on other sites More sharing options...
disco_al Posted May 5, 2010 Share Posted May 5, 2010 are you sure that's not the latest incarnation of a lucas ecu??? Quote Link to comment Share on other sites More sharing options...
garymorris Posted May 5, 2010 Share Posted May 5, 2010 have you got his phone no as I've got a stereo that wants wiring up Quote Link to comment Share on other sites More sharing options...
bobtail84 Posted May 5, 2010 Share Posted May 5, 2010 Golly Gosh... is that the proto MS3. mind you I sent 1 with the same type of welding going on... Quote Link to comment Share on other sites More sharing options...
