Cchase Posted December 27, 2016 Share Posted December 27, 2016 Probably a 'Duh' question, but if the front driveshaft was missing (broken universal) would the truck still work with just the rear driveshaft like a rear wheel drive auto? Conversely, if the rear driveshaft was not there, could you drive with just the front (diff lock on) like a front wheel drive? Thanks, Colin Quote Link to comment Share on other sites More sharing options...
western Posted December 27, 2016 Share Posted December 27, 2016 Yes But only with the transfer box difflock engaged & drive sensible with due regard to only being in 2 wheel drive. Quote Link to comment Share on other sites More sharing options...
Cchase Posted December 27, 2016 Author Share Posted December 27, 2016 Thanks, Western. Was thinking about this from a self recovery point of view. C Quote Link to comment Share on other sites More sharing options...
western Posted December 27, 2016 Share Posted December 27, 2016 I've done it in the past when a prop UJ has let go, Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted December 27, 2016 Share Posted December 27, 2016 Yep, tis fine,as above go easy though! Quote Link to comment Share on other sites More sharing options...
Stambecco Posted December 30, 2016 Share Posted December 30, 2016 If it's the rear, one must be careful to make sure the handbrake drum is secured. Quote Link to comment Share on other sites More sharing options...
IanT90 Posted December 30, 2016 Share Posted December 30, 2016 I have a question, I was led to believe that the diff lock was only for use in really slippy/extreme lack of traction conditions and only in a straight line as you can get wind up on the diff when turning ? Please excuse my ignorance as I am a first time defender owner, previously had series vehicles with no diff lock so could drive with front prop off or even with freewheel hubs. Ian Quote Link to comment Share on other sites More sharing options...
soutie Posted December 30, 2016 Share Posted December 30, 2016 As there is only one prop shaft, if the diff lock is not engaged all the drive will go to the output from the transfer box with the least resistance - the one without the propshaft. By engaging the diff lock the power is distributed 50/50 to the two outputs allowing it to drive the one prop shaft. Hope this helps explain this. The other way to think of this is the same as an axle. With a differential in it the drive goes to the wheel with the least resistance. In this case as it is the transfer box the drive would go to the output without the propshaft. Quote Link to comment Share on other sites More sharing options...
IanT90 Posted December 30, 2016 Share Posted December 30, 2016 Makes sense thanks Quote Link to comment Share on other sites More sharing options...
