western Posted September 14, 2020 Share Posted September 14, 2020 3 UK suppliers, don't know where you would get one in your area. https://www.brit-car.co.uk/product.php/237352/365/propshaft___rear___110__34____range_rover_classic___defender_ https://www.devon4x4.com/frc8389-propshaft-159391.html https://www.mm-4x4.com/defender-110-v8---rear-propshaft---frc8389-4605-p.asp Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 15, 2020 Share Posted September 15, 2020 18 hours ago, marieholm said: Thanks for the advice. I just checked the parts numbers. I have a 2.5na stw 110 with the normal lt77 and lt230 (it has a 200tdi but that should not matter right?) Can I use the FRC8389? it says that this is for the 300tdi / td5 models. directly available. the FRC8389 is for the 200tdi but has one 1 delivery time You need the earlier vehicle one. I don’t know if the transmission and axles are in different relative positions on 12J (yours) and 200Tdi era vehicles, but I suspect they’re the same. They are different positions on the later vehicles, and you’d have problems if you fit the wrong prop. Definitely go for a prop for a pre-Defender 110, 12 or 19J engine. Quote Link to comment Share on other sites More sharing options...
marieholm Posted September 15, 2020 Share Posted September 15, 2020 perfect, thanks so much for the help. Just ordered the FRC8389 and a fresh set of bolts. 1 Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted September 16, 2020 Share Posted September 16, 2020 a failing UJ has a hi pitched chatter/rattle, but only on and off the power. The only way to truly check a UJ is off the vehicle Quote Link to comment Share on other sites More sharing options...
marieholm Posted September 22, 2020 Share Posted September 22, 2020 Just fit The nee prop but it looks different. the old ons is shorter. in The shortest position The new one is slightly shorter than The old one in The longest position. I ordered The FRC8389 is it safe to fit this one? Quote Link to comment Share on other sites More sharing options...
marieholm Posted September 22, 2020 Share Posted September 22, 2020 Rechecking the numbers I think I need the FTC3245 as it is a 2,5NA originally. Hope LRdirect will take it back as it is out of the packing allready. Quote Link to comment Share on other sites More sharing options...
western Posted September 22, 2020 Share Posted September 22, 2020 See the first screenshot in here https://forums.lr4x4.com/topic/108483-1988-110-propshafts/?tab=comments#comment-983113 Quote Link to comment Share on other sites More sharing options...
marieholm Posted September 22, 2020 Share Posted September 22, 2020 Great help thanks. I think I was confused as I now have a 200tdi defender engine which replaced the 2,5na. And because I never changed the gearboxes I presumed that the props should be the same.... Just ordered the FTC3245. lets hope that one fits. Thanks for your help (and patience....) Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 23, 2020 Share Posted September 23, 2020 I’d say the one for the older spec would be fine, as that is the spec of the vehicle and the relative positions of your transmission and axle - the engine is irrelevant, being a modification. Besides, LR tolerances being what they are, a centimetre difference is about the norm for how accurately the positioned engine, gearbox and suspension brackets on the chassis. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted September 23, 2020 Share Posted September 23, 2020 Without looking at the details I’m sure everything up to and including the 200 had the same props Quote Link to comment Share on other sites More sharing options...
Snagger Posted September 23, 2020 Share Posted September 23, 2020 10 minutes ago, landroversforever said: Without looking at the details I’m sure everything up to and including the 200 had the same props I’d have thought so, but don’t know for certain. LR did change part numbers for the same part spec from time to time, though, so the different numbers could just be a reflection of that. Quote Link to comment Share on other sites More sharing options...
marieholm Posted October 9, 2020 Share Posted October 9, 2020 all, Just wanted to let you know that thanks too your advise and help I fitted the new prop this week and the landy drives great. no more clunks or scary rattles. Many thanks!!! 3 Quote Link to comment Share on other sites More sharing options...
landroversforever Posted October 9, 2020 Share Posted October 9, 2020 Glad to hear it's sorted! Quote Link to comment Share on other sites More sharing options...
Snagger Posted October 10, 2020 Share Posted October 10, 2020 Excellent! Quote Link to comment Share on other sites More sharing options...
