honitonhobbit Posted March 9, 2017 Share Posted March 9, 2017 (edited) I need to access to inaccessible grease nipples on my winch. I'm aware in the old colonies it is possible to buy flexible pipes to extend grease nipples to more accessible places. However I am unable to find such a thing here in the motherland. Any suggestions? http://www.lubecontrol.com.au/more-lubrication/remote-greasing-equipment/ like this but in the UK Edited March 9, 2017 by honitonhobbit Quote Link to comment Share on other sites More sharing options...
=jon= Posted March 9, 2017 Share Posted March 9, 2017 Go to somewhere like Pirtek and ask them to make up a short flexible hose with a 1/4" male fitting on one end (to screw into a grease nipple sized hole) and a 1/4" female on the other end (to screw a standard grease nipple into)? Quote Link to comment Share on other sites More sharing options...
=jon= Posted March 9, 2017 Share Posted March 9, 2017 (edited) http://www.hoses.co.uk/images/2015catalogue/1407.pdf http://www.hoses.co.uk/washdown-fuelling/high-pressure-lubrication-system-equipment/remote-grease-system/2-point-remote-grease-system-high-pressure-lubrication-equipment £130 though! Edited March 9, 2017 by =jon= Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted March 9, 2017 Author Share Posted March 9, 2017 Thank you - that first link might have the right bit Quote Link to comment Share on other sites More sharing options...
=jon= Posted March 9, 2017 Share Posted March 9, 2017 The second link is the same part as the first, just with a ridiculous price! Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted March 10, 2017 Author Share Posted March 10, 2017 Yes - I realised that a bit later. I rang Pirtek - that was a mistake I think I need to make something up - maybe some brake fittings, copper pipe and some bits 1 Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted March 10, 2017 Share Posted March 10, 2017 (edited) I just use standard pneumatic fittings and push fit pipe, I've never found the pressure too high to pop them apart, they're rated at 10 bar. On the machines at work if it's something that needs a constant supply of grease I use these for bearings or a centralised lubrication system for slides. http://www.directindustry.com/prod/skf-maintenance-lubrication-products/product-18813-215997.html Edited March 10, 2017 by Cynic-al 1 Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted March 10, 2017 Author Share Posted March 10, 2017 Hadn't thought of pneumatic fittings The dispenser is rather interesting. What's the lowest application rate they do? Quote Link to comment Share on other sites More sharing options...
Cynic-al Posted March 10, 2017 Share Posted March 10, 2017 You set them between 1 month and 12 month and that's roughly how long they last but obviously if the grease can't escape then it just sort of sits there under pressure. I guess it depends how well sealed the housing is and how runny the grease gets in use. The only caution I would give is I've just changed a £300 ball screw nut on a machine that had one on, it had been on about 7 years. It turns out they lose pressure and stop pumping the grease in after a certain time which is why they have a use by date They're also better fitted close to the bearing as if they have to get the grease down long thin pipes the resistance eventually overcomes the pressure in the cartridge, about 5 bar I think? They're about £20 each and are probably a bit overkill if you don't use it very often. They're meant for things like conveyors where health and safety don't like people climbing over them every day with grease guns. Quote Link to comment Share on other sites More sharing options...
muddy Posted March 10, 2017 Share Posted March 10, 2017 Air fittings 4mm pipe and a small block with tapped holes. Look at timberwolf chippers. will. Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted March 10, 2017 Author Share Posted March 10, 2017 Timberwolf chippers are something I can look at easily - thank you Quote Link to comment Share on other sites More sharing options...
muddy Posted March 10, 2017 Share Posted March 10, 2017 230 definitely has them Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted March 10, 2017 Author Share Posted March 10, 2017 Cool - I have a subbie who uses them Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted March 11, 2017 Share Posted March 11, 2017 http://www.lubetec.co.uk/ http://shop.hle.co.uk/ Both seem to offer what you're after. Writeup of an installation on a Morgan: https://sites.google.com/site/morganatica/70-modifications/remote-greasing-of-front-suspension 1 Quote Link to comment Share on other sites More sharing options...
simonr Posted March 11, 2017 Share Posted March 11, 2017 On 10/03/2017 at 10:37 AM, Cynic-al said: I just use standard pneumatic fittings and push fit pipe, I've never found the pressure too high to pop them apart, they're rated at 10 bar. That's always been my solution too. The (nylon, not Polypropylene) hoses (up to 10mm) seem to handle 70 Bar without bursting and 6mm to at least 100 Bar. Very low cost. Very easy. Suboptimal on prop-shafts! 6mm OD 4mm bore seems good for runs up to 1m 8 or 10mm for anything longer - there is a lot of viscose drag in the pipes. They can handle the pressure but it will be desperately slow! You can make your own auto greaser by half filling a reservoir with grease then pressurising it with air. Works very well so long as you keep an eye on the grease level. Likewise you can use a pneumatic cylinder. Fill the blind end with grease and fit a big spring in the rod end to push the piston down. When the rod stops sticking out of the end - it's time to refill. Si Quote Link to comment Share on other sites More sharing options...
