Arjan Posted September 9, 2018 Share Posted September 9, 2018 Right, I tried searching but did not really get a good answer, so I'll ask you kind knowledgable lot.. I need for my 185 cm heavily build body a better seat in the 110. No rear bulkhead and access to the batteries below is not an issue as they are fully switched and have a remote charge connector. I have tried the Exmoor ones and they are not for me. So, what is a good seat to look for from other cars to go in ? And, ideally, do you have any pics of thos seats in a 110.... Thank you. Quote Link to comment Share on other sites More sharing options...
SteveG Posted September 9, 2018 Share Posted September 9, 2018 People seem to manage to fit in D2 and P38 seats and both are readily available at an ok price. Would fit your comfort requirement too... Going by the pic though, they sit quite a way back. Quote Link to comment Share on other sites More sharing options...
Arjan Posted September 9, 2018 Author Share Posted September 9, 2018 Thanks. Looks as if you're sitting quite high.... But I have D1 seats here so can give it a try. Please, keep it coming... Quote Link to comment Share on other sites More sharing options...
miketomcat Posted September 9, 2018 Share Posted September 9, 2018 I have 200tdi disco seats in 45 with bulkhead still in place and I'm 6'3". Mike Quote Link to comment Share on other sites More sharing options...
Arjan Posted September 9, 2018 Author Share Posted September 9, 2018 Thanks Mike. I'll have a look at those as I must have one somewhere here... Quote Link to comment Share on other sites More sharing options...
miketomcat Posted September 9, 2018 Share Posted September 9, 2018 42 minutes ago, Arjan said: Thanks Mike. I'll have a look at those as I must have one somewhere here... They are a little higher than defender but I don't find it a problem especially if you have a smaller steering wheel. You need a frame to fit them if you want to puck up the defender bolt holes but this does allow them to slide over the lip at the back of the seatbox. Mike Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted September 9, 2018 Share Posted September 9, 2018 I've possibly got some of the more radical ones in mine. I've got a set out of a BMW era L322. I'm not as tall as you but find it quite comfortable, I've had much taller than me sit in them and all are pleasantly surprised. Can't remember if Mike sat in it properly when he helped with my windscreen. Yes you do sit a bit higher but the seats are so big and comfy there's not a huge amount in it, the people who have driven it at 6ft say its a little high but not noticeably much less visibility than normal because you can send them back quite a way. I think with normal 110 seats in the back the rear passengers (when I have humans and not dogs) would be cramped but I've fitted the rear seats too so they're much deeper and further back so you get more room than normal. Boot is a little smaller as a Co sequence but when I fabbed the seat base I made it so you have most of the width of the floor (minus 2" or so) than is now unobstructed so plenty of space for long items making it more usable. I've chopped a bit off the front and back of the runners (in hindsight not needed) and had to move the mounting holes (drilled out old captive plates and relocated them). I've also removed the front motor and bracket to drop the front low enough to be comfortable (they're designed for a flat not sloped floor). If you're a little bigger than me then a smaller steering wheel wouldn't go amiss, I'm too much of a cheap skate to change it at the moment. In terms of getting the electrics working I got it with the two control panels on the sides and you only need to give it 12V and you're away. Haven't wired up the heaters or TVs yet... When I get a bit of time I'm going to build a flatter seat box and reinstate the front motor but at the moment it's fine. Lifted up to full height you can just about get underneath the seats if you need to, I carry a few spares under the drivers seat and there's just enough room to attach big jump leads under the passenger one as well. There is a thread in Tools and Fabrication about it, although never quite finished the write up. Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted September 9, 2018 Share Posted September 9, 2018 I can get a better photo if you want. Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted September 9, 2018 Share Posted September 9, 2018 Oh and they come with an integrated arm rest. Which reminds me I need to build a more suitable cubby box, it's a little too big to open the lid fully. Quote Link to comment Share on other sites More sharing options...
Arjan Posted September 9, 2018 Author Share Posted September 9, 2018 BMW...... Interesting as they are around here - and I don't have to have electric ones as I'm the only driver.... I'll try to find the tread you mention. thank You. @Mik - yes, they need a frame. I have them in the Series... Stupid me. Smaller wheel is perfect. Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted September 9, 2018 Share Posted September 9, 2018 It was still an L322 set of seats but they're the ones that fold half way up the back. The Ford era ones do lumbar support by way of an air bag that can be moved. Although I think they originally came from a 7 series before being tweaked by Land Rover. You can't adjust them manually so electrics are needed. Quote Link to comment Share on other sites More sharing options...
reb78 Posted September 9, 2018 Share Posted September 9, 2018 Range Rover Classic seats in mine. They’re brilliant. Best £30 I ever spent - although I doubt any are that cheap now! Quote Link to comment Share on other sites More sharing options...
Arjan Posted September 9, 2018 Author Share Posted September 9, 2018 RRC seats these days fetch huge amounts..... How about Subaru etc. ? Quote Link to comment Share on other sites More sharing options...
miketomcat Posted September 9, 2018 Share Posted September 9, 2018 I had scooby seats in the tomcat comfy no idea about fittment obviously. Picture of the frame in 45 below. Mike Quote Link to comment Share on other sites More sharing options...
Arjan Posted September 9, 2018 Author Share Posted September 9, 2018 Where do these " scooby seats " originate from Mike ? Quote Link to comment Share on other sites More sharing options...
miketomcat Posted September 10, 2018 Share Posted September 10, 2018 Subaru impreza is known as scooby over here. Mike Quote Link to comment Share on other sites More sharing options...
Arjan Posted September 10, 2018 Author Share Posted September 10, 2018 Excuse my ignorance..... English is not my native tongue... Thanks Quote Link to comment Share on other sites More sharing options...
miketomcat Posted September 10, 2018 Share Posted September 10, 2018 1 hour ago, Arjan said: Excuse my ignorance..... English is not my native tongue... Thanks Not at all. Your English is better than mine. As soon as I saw your reply I realised my mistake in assuming everyone called them Scooby's. They are nice seats though how they would fit I don't know. RX7 and smart are other seats that would be worth a look. I've got freelander seats in the ibex but they won't work with the seatbox. Mike Quote Link to comment Share on other sites More sharing options...
Arjan Posted September 10, 2018 Author Share Posted September 10, 2018 No worries. I'm looking for the D1 seat option for now. Quote Link to comment Share on other sites More sharing options...
Ed Poore Posted September 10, 2018 Share Posted September 10, 2018 @Chris Davies might have some? Quote Link to comment Share on other sites More sharing options...
Arjan Posted September 10, 2018 Author Share Posted September 10, 2018 Thanks. IF all goes according to lpan, I'll be in the UK late Nov - Dec. collecting bits, some D1 seats including. Quote Link to comment Share on other sites More sharing options...
ballcock Posted September 10, 2018 Share Posted September 10, 2018 22 hours ago, Arjan said: Where do these " scooby seats " originate from Mike ? The full explanation if you are still unsure why, rhyming slang Scooby Doo - Subaru Quote Link to comment Share on other sites More sharing options...
Arjan Posted September 10, 2018 Author Share Posted September 10, 2018 😁 Quote Link to comment Share on other sites More sharing options...
