Exterior Winch Switch !!
TJ101
Mark....where did you get the red rubberised plastic covers that go over the motor connection?
They are from phil at PG Winches www.pgwinches.co.uk
Not cheap, about £1.50 each IIRC, but fit better than anything else I found.
I have the same fitted to the solenoid connections too.
David Bowyer sells black ones and red ones as do OEC4x4. IIRC they are a snadge less than a quid but I won't swear to it
I use the Rocker Switches from www.waytekwire.com that are 100% the same as ARB switches...I have 3 switches per winch, one inside, and two outside per corner, for both the front and rear winches. Also, I have a on/off to activate all these switches as a safety margin.
what HP is your winch then Mark?
I bought it second hand so not really sure :unsure: I reckon the previous owner put that sticker on a 2hp ;)
does this mean your going to get out of the hybrid sometime then tim.
Hell no, why press a button yourself when you have a winch bitch to do that for you, I only put one outside so save me having to use the one inside :lol:
