TJ101 Posted December 23, 2006 Share Posted December 23, 2006 Can someone point me in the right direction, as to where to obtain a exterior winch switch, momentry on/off/on and weatherproof !! 4.5 hp 24v Thanks Guys Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted December 23, 2006 Share Posted December 23, 2006 Can someone point me in the right direction, as to where to obtain a exterior winch switch, momentry on/off/on and weatherproof !! 4.5 hp 24v Thanks Guys Les Brock Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 23, 2006 Share Posted December 23, 2006 Vehicle Wiring Products do one I think Edited to say yes they do look here "splashproof metal lever switch" about half way down Quote Link to comment Share on other sites More sharing options...
TJ101 Posted December 23, 2006 Author Share Posted December 23, 2006 Thanks Stephen,, was just in their pages was think more like a 49600 Mom/Off/Mom. with a LHD Waterproof screw on hood ?? Evening David ! Quote Link to comment Share on other sites More sharing options...
Petergg Posted December 23, 2006 Share Posted December 23, 2006 I use one from Durite it has a rubber boot, been OK for past 4yrs. Peter Quote Link to comment Share on other sites More sharing options...
landmannnn Posted December 23, 2006 Share Posted December 23, 2006 RS components sell these. They also have screw connectors instead of push on type. Quote Link to comment Share on other sites More sharing options...
Mark90 Posted December 23, 2006 Share Posted December 23, 2006 was think more like a 49600 Mom/Off/Mom. with a LHD Waterproof screw on hood ?? That's what I used. Quote Link to comment Share on other sites More sharing options...
dirtydiesel Posted December 23, 2006 Share Posted December 23, 2006 I use the 49650 splash proof metal lever swtch, it is made by durite and is identical to the ones devon sell (only cheaper). The 49600 aren't of the same quality. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted December 23, 2006 Share Posted December 23, 2006 What's a DFENDER? Quote Link to comment Share on other sites More sharing options...
Bush65 Posted December 23, 2006 Share Posted December 23, 2006 What's a DFENDER? Shorter wheelbase than a Defender, but not quite as short as a Fender Quote Link to comment Share on other sites More sharing options...
streaky Posted December 24, 2006 Share Posted December 24, 2006 Mark....where did you get the red rubberised plastic covers that go over the motor connection? I've been looking forever and can't find any in Dubai. Ard's coming over soon...I could ask him to pick some up. Cheers. S. Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted December 24, 2006 Share Posted December 24, 2006 http://www.power-store.com/view-item.asp?i...amp;id=134& Quote Link to comment Share on other sites More sharing options...
Mark90 Posted December 24, 2006 Share Posted December 24, 2006 Mark....where did you get the red rubberised plastic covers that go over the motor connection? They are from phil at PG Winches www.pgwinches.co.uk Not cheap, about £1.50 each IIRC, but fit better than anything else I found. I have the same fitted to the solenoid connections too. Quote Link to comment Share on other sites More sharing options...
JST Posted December 24, 2006 Share Posted December 24, 2006 what HP is your winch then Mark? Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted December 24, 2006 Share Posted December 24, 2006 They are from phil at PG Winches www.pgwinches.co.ukNot cheap, about £1.50 each IIRC, but fit better than anything else I found. I have the same fitted to the solenoid connections too. David Bowyer sells black ones and red ones as do OEC4x4. IIRC they are a snadge less than a quid but I won't swear to it Quote Link to comment Share on other sites More sharing options...
DiscoDino Posted December 24, 2006 Share Posted December 24, 2006 I use the Rocker Switches from www.waytekwire.com that are 100% the same as ARB switches...I have 3 switches per winch, one inside, and two outside per corner, for both the front and rear winches. Also, I have a on/off to activate all these switches as a safety margin. Quote Link to comment Share on other sites More sharing options...
Victor Posted December 24, 2006 Share Posted December 24, 2006 does this mean your going to get out of the hybrid sometime then tim. Quote Link to comment Share on other sites More sharing options...
TJ101 Posted December 24, 2006 Author Share Posted December 24, 2006 does this mean your going to get out of the hybrid sometime then tim. No,, Just tryng to speed the winch bitch up a bit Quote Link to comment Share on other sites More sharing options...
Mark90 Posted December 24, 2006 Share Posted December 24, 2006 what HP is your winch then Mark? I bought it second hand so not really sure I reckon the previous owner put that sticker on a 2hp does this mean your going to get out of the hybrid sometime then tim. Hell no, why press a button yourself when you have a winch bitch to do that for you, I only put one outside so save me having to use the one inside Quote Link to comment Share on other sites More sharing options...
