ThreeSheds Posted February 28, 2019 Share Posted February 28, 2019 While doing some work on the TD5 Disco the other day I accidentally caught the steel coolant pipe that runs behind the rad-stack with a grinder and put a little groove in it. It's not right through but I think that with temperature cycling and vibrations it would not be a good idea to leave it since it would almost certainly crack. Since that pipe is expensive and looks like a bit of a pain to fit I was thinking of mig welding it in situ. I have drained that coolant, but there may still be a small amount of it behind where I would be welding. Is that likely to be a problem? (I am good enough that I won't be blowing through the steel, and I would clean the area first) Cheers Rog Quote Link to comment Share on other sites More sharing options...
Blanco Posted February 28, 2019 Share Posted February 28, 2019 A drop of water can be a pain when soldering, but I would have though less so with the partial thickness situation and a MIG. Can one end be undone and dropped down? Quote Link to comment Share on other sites More sharing options...
qwakers Posted February 28, 2019 Share Posted February 28, 2019 (edited) i wouldnt do it with anything in the pipe. it wont work. at best itll end up brittle. also, i would doubt that that will fail, ive run worse for years. if your worried about it carry a length of hose and some jubilee clips for a emergency repair. Edited February 28, 2019 by qwakers Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted February 28, 2019 Share Posted February 28, 2019 As qwakers said, I'd almost be inclined to leave it alone - whack a bit of paint over it to stop it corroding. Right now it's not leaking - welding it you risk adding a pinhole or inclusion that WILL leak / corrode. Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted February 28, 2019 Author Share Posted February 28, 2019 thanks for the advice gents - bearing in mind what you have said I will clean it up and put some of that "QuickSteel" over it... I will also check that the water level switch in the header tank is working - just in case Rog Quote Link to comment Share on other sites More sharing options...
Farmerfred Posted March 5, 2019 Share Posted March 5, 2019 Clean up the area around the nick with some medium wire wool and do a little mix of 2 part epoxy resin, like Areldite and pool it around and over the nick, let it harden off and spray a bit of silver paint over it, you'll see then if it leaks inn the future at all. 1 Quote Link to comment Share on other sites More sharing options...
Jon W Posted March 12, 2019 Share Posted March 12, 2019 I have a good condition pipe here you can have for £40, I brought it from a breaker as mine corroded through where the 2 pipes are welded together. it wasn’t too bad a job to swap over, a couple of clips were a pain to get the pliers onto but otherwise ok. let me know if you want it and I can get it package up Thanks Quote Link to comment Share on other sites More sharing options...
ThreeSheds Posted March 12, 2019 Author Share Posted March 12, 2019 11 minutes ago, Jon W said: I have a good condition pipe here you can have for £40, I brought it from a breaker as mine corroded through where the 2 pipes are welded together. it wasn’t too bad a job to swap over, a couple of clips were a pain to get the pliers onto but otherwise ok. let me know if you want it and I can get it package up Thanks Thanks, but it's done now... Quote Link to comment Share on other sites More sharing options...
