Kennykirk Posted April 14, 2019 Share Posted April 14, 2019 Hey wondering if anyone can help. I have 300tdi 1994 Manuel and after taking her to devils today I now only have drive to front wheels and only when diff locks are on. Befor I just start taking things apart not knowing what to look for and where. Has anyone have any idea what it could be added pic just so u could see her Quote Link to comment Share on other sites More sharing options...
western Posted April 14, 2019 Share Posted April 14, 2019 probably a stripped or broken drive shaft at the diff end. Quote Link to comment Share on other sites More sharing options...
steve b Posted April 14, 2019 Share Posted April 14, 2019 broken cross shaft or split planet gear - both in the rear diff cheers Steve b Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 14, 2019 Share Posted April 14, 2019 With difflock OUT, does the rear propshaft turn? If NO I'd suspect the transfer box. If YES it's the back axle. If it's the back axle it's either a half-shaft or the diff. You can remove the half shafts without even jacking a wheel up, and you'd have to remove them to change a diff anyway so may as well check 1st. Quote Link to comment Share on other sites More sharing options...
Farmerfred Posted April 16, 2019 Share Posted April 16, 2019 Transfer box input shaft fail? Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted April 16, 2019 Share Posted April 16, 2019 1 hour ago, Farmerfred said: Transfer box input shaft fail? That would give no drive at all surely? Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted April 16, 2019 Share Posted April 16, 2019 8 minutes ago, FridgeFreezer said: That would give no drive at all surely? yup, no drive with a broken input shaft Quote Link to comment Share on other sites More sharing options...
BogMonster Posted April 16, 2019 Share Posted April 16, 2019 Was there a decent sized bang or anything like that? That vehicle will have a 2 pin rear diff which probably looks like the next stage of this one which is about 1 decent welly boot full of throttle away from a fkin big bang and much the same symptoms... Quote Link to comment Share on other sites More sharing options...
