Mo Murphy Posted May 18, 2019 Share Posted May 18, 2019 So, with a new rear door coming my thoughts turn to how to seal the old type rear door glass now that dum-dum is no more. What are people using now ? Is there something that won't dry out and fall out like dum-dum does ? Mo Quote Link to comment Share on other sites More sharing options...
ianmayco68 Posted May 18, 2019 Share Posted May 18, 2019 Sp4x4 sell some stuff Mo, I’ve got some for mine , I’ve used it before on the 110 and it works well. 1 Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted May 18, 2019 Author Share Posted May 18, 2019 Do you know what it's called, Ian ? Quote Link to comment Share on other sites More sharing options...
western Posted May 18, 2019 Share Posted May 18, 2019 14 minutes ago, Mo Murphy said: Do you know what it's called, Ian ? This is the stuff https://www.sp-4x4.com/product_p/arbo1.htm 1 Quote Link to comment Share on other sites More sharing options...
Badger110 Posted May 18, 2019 Share Posted May 18, 2019 (edited) If i may add to this, the item listed is a butyl strip with adhesive added to allow the glass to stick to it. If you visit a builders merchants, or B&Q, Screwfix then you could pick up some flash band which is a similar product and has added benefits around the vehicle other than windows ( it's wider than the strip ). I use flash band on the bodywork at the base of doors to protect from standing water over time as these areas become prone to water ingress. Just a thought bodywork at the bottom of the tub by the rear door. ( dog posing for scale ) Edited May 18, 2019 by Badger110 added pictures 1 Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted May 20, 2019 Share Posted May 20, 2019 Mo, I used a tube of sealant for my rear window. I think it was something like this: https://www.ebay.co.uk/i/290816400419 Steve (I searched for windscreen tube sealant) 1 Quote Link to comment Share on other sites More sharing options...
daveturnbull Posted May 21, 2019 Share Posted May 21, 2019 Pretty sure I stuck mine in with a generous bead of RTV, probably because I had some to hand, and it's good stuff. Quote Link to comment Share on other sites More sharing options...
