Stellaghost Posted January 15, 2020 Share Posted January 15, 2020 I'm with supaimpy when I put my 200tdi into lightweight I used 300tdi manifold etc way easier to sort for rest of exhaust run regards Stephen Quote Link to comment Share on other sites More sharing options...
Ex Member Posted January 15, 2020 Share Posted January 15, 2020 16 hours ago, reb78 said: I haven’t looked but it must be bad as the Steve Parker stuff looks awful in the first place!! Huh? Quote Link to comment Share on other sites More sharing options...
reb78 Posted January 15, 2020 Share Posted January 15, 2020 8 minutes ago, Red90 said: Huh? As I said earlier - i recall the earlier steve parker stuff looked pretty bad too. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted January 15, 2020 Share Posted January 15, 2020 47 minutes ago, reb78 said: As I said earlier - i recall the earlier steve parker stuff looked pretty bad too. So you are complaining about something that a company used to make at some point in the past? Quote Link to comment Share on other sites More sharing options...
reb78 Posted January 15, 2020 Share Posted January 15, 2020 1 hour ago, Red90 said: So you are complaining about something that a company used to make at some point in the past? Just forget it, I wish I hadn't mentioned it. 3 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted January 15, 2020 Share Posted January 15, 2020 3 hours ago, reb78 said: As I said earlier - i recall the earlier steve parker stuff looked pretty bad too. That does look worlds away (better) then the type I remember - and I too didn’t realised they’d changed design 👍🏻 1 Quote Link to comment Share on other sites More sharing options...
Anderzander Posted January 15, 2020 Share Posted January 15, 2020 4 hours ago, Stellaghost said: I'm with supaimpy when I put my 200tdi into lightweight I used 300tdi manifold etc way easier to sort for rest of exhaust run regards Stephen I used the 300 manifolds too. Perhaps a little more awkward for some of the other pipework - but loads better for the exhaust. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 15, 2020 Share Posted January 15, 2020 4 hours ago, reb78 said: Just forget it, I wish I hadn't mentioned it. To be honest, I remember their earlier stuff looked way worse, but I am talking about 10yrs plus. New one looks great 1 Quote Link to comment Share on other sites More sharing options...
andy _1 Posted January 21, 2020 Author Share Posted January 21, 2020 God that generated alot of debate, mines just straight out and down with a 90 exhaust bend to couple to a 200 tdi downpipe cut. Cost £18 3 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted January 21, 2020 Share Posted January 21, 2020 Looks very tidy too Quote Link to comment Share on other sites More sharing options...
Anderzander Posted January 21, 2020 Share Posted January 21, 2020 It does look neat ! Super long studs look to justify a power tool to take it off though 😀 Quote Link to comment Share on other sites More sharing options...
reb78 Posted January 21, 2020 Share Posted January 21, 2020 It does look nice and very simple compared to the contorted stuff pictured before.... Is it a little close to the clutch pipe (think thats the one directly behind it?)? Are you planning a heatsheild/move the pipe? Quote Link to comment Share on other sites More sharing options...
andy _1 Posted January 22, 2020 Author Share Posted January 22, 2020 14 hours ago, reb78 said: It does look nice and very simple compared to the contorted stuff pictured before.... Is it a little close to the clutch pipe (think thats the one directly behind it?)? Are you planning a heatsheild/move the pipe? Yes it is close they move the pipe round the corner , there is very little room. That's all the room you have. I see what happens . If it fine there It will stay if not I'll move it. Quote Link to comment Share on other sites More sharing options...
reb78 Posted January 22, 2020 Share Posted January 22, 2020 Fair enough. You get the same issue down by the slave cylinder with the standard setup and some people have heatsheilds, some not but the problems dont seem to be one or the other so it could be fine. Quote Link to comment Share on other sites More sharing options...
miketomcat Posted January 22, 2020 Share Posted January 22, 2020 On our 90 (Steve Parker exhaust) I wrapped the clutch pipe in a bit of plumbers heat mat then taped it up with foil tape. Never had any issues. Mike Quote Link to comment Share on other sites More sharing options...
