white90 Posted January 5, 2007 Share Posted January 5, 2007 Anyone know where I can get some? my local place can't help cheers Quote Link to comment Share on other sites More sharing options...
pux Posted January 5, 2007 Share Posted January 5, 2007 Anyone know where I can get some?my local place can't help cheers i suspect you already have tried them, but what about devon4x4 Quote Link to comment Share on other sites More sharing options...
white90 Posted January 5, 2007 Author Share Posted January 5, 2007 Sorted thanks Gigglepin are ordering me one in the tyre will just be a spare as it has a slow puncture. Quote Link to comment Share on other sites More sharing options...
Hybrid_From_Hell Posted January 5, 2007 Share Posted January 5, 2007 TC Try asking for 900x16 truck tubes, swat I use, albiet 34s x10.50x16 ? Nige Quote Link to comment Share on other sites More sharing options...
white90 Posted January 5, 2007 Author Share Posted January 5, 2007 they had those but the valve stems were too big for the modular rims Quote Link to comment Share on other sites More sharing options...
pux Posted January 5, 2007 Share Posted January 5, 2007 they had those but the valve stems were too big for the modular rimsglad u got it sorted fella Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 5, 2007 Share Posted January 5, 2007 they had those but the valve stems were too big for the modular rims Tony, If you have tubeless rims you need to ask for (or order) 9.00x16TR13 if available. The tube type Land Rover rims (and many truck rims) are TR15 valves i.e. 15mm hole not 13mm. Quote Link to comment Share on other sites More sharing options...
white90 Posted January 5, 2007 Author Share Posted January 5, 2007 Cheers Stephen I guess gigglepin will know what I need I told him which tyre/rim I have. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted January 6, 2007 Share Posted January 6, 2007 I expect so. Technically you need a 35x10.50R16TR13 but I doubt such a thing exists! - but most tubes will do a range of different tyre sizes anyway. Some folks here will put 7.50x16 tubes in just about anything Quote Link to comment Share on other sites More sharing options...
will_warne Posted January 6, 2007 Share Posted January 6, 2007 Tony, make sure you do Jim's cable tie mod around the valve stem (I'm sure it was Jim's idea....) as I had no end of problems (including spinning the tubes) when I switched to running tubes. Quote Link to comment Share on other sites More sharing options...
Lewis Posted January 6, 2007 Share Posted January 6, 2007 Tony, make sure you do Jim's cable tie mod around the valve stem (I'm sure it was Jim's idea....) as I had no end of problems (including spinning the tubes) when I switched to running tubes. Will, can you give any more details on the cable tie mod? I've got to go tube on one of the simex on the 110 as it has a sizeable hole Lewis Quote Link to comment Share on other sites More sharing options...
JST Posted January 6, 2007 Share Posted January 6, 2007 Tony, you get the other rim sorted after today? Quote Link to comment Share on other sites More sharing options...
white90 Posted January 6, 2007 Author Share Posted January 6, 2007 no not yet had 2 go down thanks to treebloke for the loan f the gear to sort them Quote Link to comment Share on other sites More sharing options...
will_warne Posted January 6, 2007 Share Posted January 6, 2007 Will, can you give any more details on the cable tie mod? I've got to go tube on one of the simex on the 110 as it has a sizeable hole Lewis Put a cable tie on the valve stem on the outside of the rim to stop the tube spinning and the valve going on holiday inside the rim. Been therer done that. Oh, and if you're tubing because of a hole, get it patched up first using vucanising <sp?> solution otherwise muck'll get straight into the tyre and rub a hole in the tube. Quote Link to comment Share on other sites More sharing options...
treebloke Posted January 7, 2007 Share Posted January 7, 2007 no not yethad 2 go down thanks to treebloke for the loan f the gear to sort them We let some air out of ours to get a bit a traction on one of the punch's and forgot to blow them back up. Thought I had bent the steering when we got on the main road. Soon sorted though. I bought my Simex second hand but as new. They had tubes in and I kept getting punctures. Seems simex do not get on with tubes very well?. Quote Link to comment Share on other sites More sharing options...
will_warne Posted January 8, 2007 Share Posted January 8, 2007 We let some air out of ours to get a bit a traction on one of the punch's and forgot to blow them back up. Thought I had bent the steering when we got on the main road. Soon sorted though.I bought my Simex second hand but as new. They had tubes in and I kept getting punctures. Seems simex do not get on with tubes very well?. I'd agree. Before I sell mine they'll be pulled off the rims and the tubes removed. Quote Link to comment Share on other sites More sharing options...
