Falklandislander2003 Posted February 1, 2021 Share Posted February 1, 2021 Hello all I have a 200 tdi 110 and she appears to have a heat problem after about half an hour of running shes below the red on the temperature gauge doesnt seem to have any difference to the engines running she has a turly turbo fitted so i dont know if thats making the engine more hot suggestions please cheers Tom Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted February 1, 2021 Share Posted February 1, 2021 Check your thermostat is not sticking this preventing flow to the radiator, if your losing water and it's not obvious you may need to check head gasket regards Stephen Quote Link to comment Share on other sites More sharing options...
Snagger Posted February 2, 2021 Share Posted February 2, 2021 Does it make any difference when you switch the lights or heater fan on? If so, it could be a false over reading caused by a bad earth for the gauges, lighting or fan switch in the dash. Quote Link to comment Share on other sites More sharing options...
western Posted February 2, 2021 Share Posted February 2, 2021 What state are the radiator fins in, if most have disintegrated then that will give higher temps as the rad cannot disperse the excess heat. Quote Link to comment Share on other sites More sharing options...
Falklandislander2003 Posted February 2, 2021 Author Share Posted February 2, 2021 Firstly im an absolute begginer in this gig so here we go Radiator seems to be in good condition, Western cant see that any fins have disintegrated Stellaghost, as stupid as this seems i dont actually know where the thermostat is in the engine bay cheers Tom Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted February 2, 2021 Share Posted February 2, 2021 7 hours ago, Falklandislander2003 said: i dont actually know where the thermostat is in the engine bay cheers Tom Follow the top hose from radiator it will fasten onto a removable ( usually 3 bolts )aluminium housing on the top front of the engine your thermostat will be inside, remove it give it a clean put it in a jug and pour boiling water onto it you should be able to see it open if it opens then it's working ok regards Stephen Quote Link to comment Share on other sites More sharing options...
Eightpot Posted February 2, 2021 Share Posted February 2, 2021 Is the car a 200tdi from the factory, or is it an engine conversion? Quote Link to comment Share on other sites More sharing options...
gruntus Posted February 4, 2021 Share Posted February 4, 2021 Faulty temp sensor? Just a thought. G Quote Link to comment Share on other sites More sharing options...
Roverdrive Posted February 6, 2021 Share Posted February 6, 2021 When checking the radiator fins look on the back side nearest the fan as that is where they tend to rot. The front can look perfect. 1 Quote Link to comment Share on other sites More sharing options...
