200 TDI Heat issue
Hello all
I have a 200 tdi 110 and she appears to have a heat problem
after about half an hour of running shes below the red on the temperature gauge
doesnt seem to have any difference to the engines running
she has a turly turbo fitted so i dont know if thats making the engine more hot
suggestions please
cheers Tom
7 hours ago, Falklandislander2003 said:
 i dont actually know where the thermostat is in the engine bay
cheers
Tom
Follow the top hose from radiator it will fasten onto a removable ( usually 3 bolts )aluminium housing on the top front of the engine your thermostat will be inside, remove it give it a clean put it in a jug and pour boiling water onto it you should be able to see it open if it opens then it's working ok regards Stephen
