MikeAK Posted April 18, 2021 Share Posted April 18, 2021 I've just been given a box of old tools most of it useful stuff, but it also contained this. I have no idea what it is or what it's used for. Thought someone on here may know. The knurled knob at the bottom alters the position of the hook. The lever closes the jaws and doesn't move the hook. Mike Quote Link to comment Share on other sites More sharing options...
western Posted April 18, 2021 Share Posted April 18, 2021 Might be a nibbler for cutting slots in thin sheet metal. Don't think I have seen anything like it before so just a guess. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted April 19, 2021 Share Posted April 19, 2021 I’m stumped on the hook bit, could it be wire strippers? Quote Link to comment Share on other sites More sharing options...
JohnnoK Posted April 20, 2021 Share Posted April 20, 2021 Some sort of tying/tightening and cutting tool, maybe? Quote Link to comment Share on other sites More sharing options...
De Ranged Posted April 21, 2021 Share Posted April 21, 2021 This is a guess.... but it looks like some form of CV boot band setting tool Use the hook to tension the strap then crush the clamp to lock the strap and the "top" blade thing'ie is a guage tool to lock into the band and pull against I have used a tool (borrowed from another mechanic) that was similar.... didn't have a hook like that, it had a little hook you folded the end of the strap into from the side Quote Link to comment Share on other sites More sharing options...
HoSS Posted April 22, 2021 Share Posted April 22, 2021 Pretty sure thats a safety wire tool, as used in aviation and motor racing. Does the inner part of the tool spin with the knurled know on the end. You hook the loop of wire onto the hook, spin to twist and then cut off. Quote Link to comment Share on other sites More sharing options...
JohnnoK Posted April 23, 2021 Share Posted April 23, 2021 15 hours ago, HoSS said: Pretty sure thats a safety wire tool, as used in aviation and motor racing. Does the inner part of the tool spin with the knurled know on the end. You hook the loop of wire onto the hook, spin to twist and then cut off. No, it's not that. I have used wire twisters in aviation for over 30 years now, and I have never seen that tool before. These are your generic wire twisters Deep reach aviation type rebar tie twister Quote Link to comment Share on other sites More sharing options...
