Stellaghost Posted April 26, 2021 Share Posted April 26, 2021 Never noticed this before or am I just being thick ( dont answer that ) Was trial fitting a prop shaft onto my rear portal today and it just did not look right . When I turn prop through 90 degrees the angles are not equal you will see better in the pictures Prop held level Prop dropped Prop turned through 90 degrees Y Your probably all laughing now at my possible senior moment but I'm just not getting this difference in angular movement I would have thought it would be equal at all points of the rotation confused regards Stephen Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted April 26, 2021 Share Posted April 26, 2021 You mean those are the angles it binds at.....? Confess I am a bit confused as to what is wrong Quote Link to comment Share on other sites More sharing options...
elbekko Posted April 26, 2021 Share Posted April 26, 2021 Binding on the grease nipple maybe? Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted April 26, 2021 Author Share Posted April 26, 2021 These photos might explain better with prop flange flat on the table and shaft leaning over onto axle casing you get this angle and distance in from table edge However if you turn prop through 90 degrees you get this angle and prop is further in from the end of the table I would have thought this positioning would remain the same but it doesn't. I have also checked two different landrover props and same issue ???? Regards Stephen Quote Link to comment Share on other sites More sharing options...
steve b Posted April 26, 2021 Share Posted April 26, 2021 It's the shorter centre height of the x pin to the mounting flange ( to diff) . The early RRC props had much deeper yokes on the diff mounting section . I think there are suppliers that have these deeper yokes on new props Steve 1 Quote Link to comment Share on other sites More sharing options...
zardos Posted April 26, 2021 Share Posted April 26, 2021 (edited) I checked 2 different props and they seem to have equal deflection in both directions. But it is totally possible to have deflection values as the limiting factor on each directions is a different part of the prop. They could have different yoke depths and styles of cutouts on the the flange side. I note that it looks like a gap pointed to in the picture below with the red arrow is different to mine which move until there is no gap in this direction/ Edited April 26, 2021 by zardos Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted April 26, 2021 Author Share Posted April 26, 2021 3 minutes ago, steve b said: It's the shorter centre height of the x pin to the mounting flange ( to diff) . The early RRC props had much deeper yokes on the diff mounting section . I think there are suppliers that have these deeper yokes on new props Steve This would explain it I guess just cannot understand why it would be designed and configured like that regards Stephen Quote Link to comment Share on other sites More sharing options...
Escape Posted April 27, 2021 Share Posted April 27, 2021 On the propside, the yoke is rather slim as it only connects to the tube. On the other side, the yoke attaches to the flage, which is a larger diameter so will cause binding at a smaller angle. As the prop is not designed for the extreme angles allowed by the small side, is doesn't really matter if the other angle is slightly larger. So the cutout was probably a compromise between the minimum angle needed and the strength of the flange. Quote Link to comment Share on other sites More sharing options...
