Series Dashboard in a Defender ?
Asking for a friend (....)
As the warning lights etc. are invisible and he is not too impressed by the standard dash, does anybody have done this ?
Any pics ?
Also, is there a Tacho (Rev. Counter) that would nicely fit the Series dash ?
Thank you
He could use the Td5 instrument pack, it has a led warning light panel & all the info to fit if on here in the wibnly wobbly speedo post & summarised on retroanacondas Web pages. I would say a Series 3 dash is a backward step.
Aside from nicer switches, theres not much to gain really - surely some brighter bulbs or swapping the instruments out for VDO would save a load of hassle..  If I were going to retrofit a dash I'd go further back to S2/2a style, much smarter.
In case your friend doesn't know - the dash binnacles are different, it's not a bolt-in jobby and there's a support bar that may well be in the way.
If he just wants brighter warning lights, find some decent LED bulbs to replace them with.
Anything is of course possible...
I have fitted a couple of series 3 dash to 90s (pre Defender) and it all physically fitted as far as I can remember. Wiring was easy to sort out. I dont think a TD5 or Puma would be easy regarding the wiring.
Why on earth would you want a rev counter ? They are a waste of time on anything other than a performance car. Just eye candy on everything else.
The sonic rev counter tells you all you need to know !
  • Like 1
If you transplant the whole dash yes - the binnacles and dash top are different though, so you can't just swap the instruments across easily.
Well yes. That is what I meant. I assumed he meant the whole dash including the MUCH nicer dash top of the series 3. Great to put things on !
My favourite is the really early series 3 top with the full width windscreen vents.
