SimonBirch Posted October 13, 2021 Share Posted October 13, 2021 How can I tell which rear half shaft is broken? Quote Link to comment Share on other sites More sharing options...
Diff Posted October 13, 2021 Share Posted October 13, 2021 Most likely to be the short one as it doesn't twist as far as the long one. Chock the wheels and unbolt the drive member and withdraw the drive member and half shaft assembly. You can then see if it is broken. Regards, Diff. Quote Link to comment Share on other sites More sharing options...
missingsid Posted October 13, 2021 Share Posted October 13, 2021 Then again the long one does twist a full turn hiding the weakness then let's go! Sorry the two I broke were long ones. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted October 13, 2021 Share Posted October 13, 2021 Replace both, the other one isn't far behind. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 13, 2021 Share Posted October 13, 2021 Jack up each separately and spin the wheel, whichever turns the prop is OK. 1 Quote Link to comment Share on other sites More sharing options...
Snagger Posted October 14, 2021 Share Posted October 14, 2021 A broken half shaft is going to result in minimal resistance through the open diff, so neither the broken nor good side are likely to turn the prop shaft, unfortunately. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted October 14, 2021 Share Posted October 14, 2021 I said each separately Quote Link to comment Share on other sites More sharing options...
Snagger Posted October 14, 2021 Share Posted October 14, 2021 Still not going to work - the broken side won’t turn anything, the good side will spin the diff centre and the broken stub in the opposite direction, but might not rotate the prop because of the mechanical drag of the UJs and transfer box innards. But you might hear grinding of the broken ends on rotation of one wheel, if the shaft hasn’t moved in its splines. Quote Link to comment Share on other sites More sharing options...
Daan Posted October 14, 2021 Share Posted October 14, 2021 Remove both shafts and it is obvious; they are going to need to come off anyway to remove the diff. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted October 14, 2021 Share Posted October 14, 2021 Yes. And replace both. Quote Link to comment Share on other sites More sharing options...
