uninformed Posted December 12, 2021 Share Posted December 12, 2021 Hey all. I will be fitting Series style doors to my 110 build. While im researching mirrors and lights, it makes sense to order my locks/latches as well and get it done. I have 2 sets of front doors, with and without the door lock barrel hole. I would like to fit Anit Burst Door Locks. I did some searching but couldnt find if there are any differences between the various part numbers other than L&R. I saw 395038 for the Series LH FQJ103840 for RH and rear, but some sites say rear only?? STC2872 full kit LH Then on P A BLanchard there are a myriad of part numbers but no pics and little description. Is there a series style anti burst door lock that uses the defender style srticker? IN short im looking for the part numbers of the best suited style. ANd any brands to go for or avoid? cheers Quote Link to comment Share on other sites More sharing options...
uninformed Posted December 12, 2021 Author Share Posted December 12, 2021 I managed to get to my storage and check my doors. Here’s what I have. Right side: Left side: ( obligatory Australian spider) Quote Link to comment Share on other sites More sharing options...
uninformed Posted December 12, 2021 Author Share Posted December 12, 2021 (edited) The other 2 which must be pre locks, looks like ex Aus military and S2/2a going by the witness marks left from the hinges. I took a pic but it’s useless Edited December 12, 2021 by uninformed Quote Link to comment Share on other sites More sharing options...
GregK Posted December 12, 2021 Share Posted December 12, 2021 Hi. Here are the part numbers I found on Ebay listing for SERIES ANTI BURST DOOR CONVERSION KIT FOR DEFENDER INC HANDLES STRIKERS LOCKS and the part numbers are: FQB500160, FQB500170, MTC6504, 395038, 395037. As far as I'm aware anti burst locks [as per yellow doors] were only fitted to military series vehicle. The green doors I presume have same hole to mount the locks but minus the hole for key barrel which can be drilled and anti burst will fit. 1 Quote Link to comment Share on other sites More sharing options...
uninformed Posted December 12, 2021 Author Share Posted December 12, 2021 Thanks @GregK The yellow doors are civilian Seriers III. Going by what I think are date codes on the locks, must have been a 79’ build or later??? Australia market btw. I should clarify, I had assumed that if the door latch had a key/barrel/lock that it must be anti burst. That may not be the case. Ill google those part numbers you’ve added when I can sit at my desktop and cross check stuf. My build is based on a 110 Cab Chassis (tray back Ute) but as a hardtop or truck cab 110 tubs are rarer than rocking horse…. over here, I’m going to customise a SII/IIA 109 tub. I will most probably use my 110 truck cab rear lower bulkhead and graft it into the old 109 tub. Quote Link to comment Share on other sites More sharing options...
uninformed Posted December 12, 2021 Author Share Posted December 12, 2021 Does anyone know if the later, early 110/MOD anti burst door locks will fit the door? Are they better? Are they better suited? part numbers: MUC1030 MUC1031 MRC8444 MRC8445 cheers. Quote Link to comment Share on other sites More sharing options...
smallfry Posted December 12, 2021 Share Posted December 12, 2021 I have got some early 110 doors and strikers, but they are twenty miles from here. Strikers are NOT the same as Defender ones, they are just the pin, and do not have the wrap around closing piece. Need a photo really ! Lot easier. I have had a lot of LRs, but never an ex military series. AFAIK, I dont recall seeing anti burst locks on a Civvy series here. 1 Quote Link to comment Share on other sites More sharing options...
GregK Posted December 13, 2021 Share Posted December 13, 2021 1 hour ago, uninformed said: I should clarify, I had assumed that if the door latch had a key/barrel/lock that it must be anti burst. That may not be the case. Standard lock do have a lock as well but they are fitted above the handle without a hole in door skin. if you search for good pic of this part number 337801 you will se a difference between standard and anti burst lock. Mine is an ex military and has a anti burst locks the previous s3 was a civilian and it had standard locks fitted. Sorry can't help with later defender stuff. 1 Quote Link to comment Share on other sites More sharing options...
uninformed Posted December 13, 2021 Author Share Posted December 13, 2021 1 hour ago, smallfry said: I have got some early 110 doors and strikers, but they are twenty miles from here. Strikers are NOT the same as Defender ones, they are just the pin, and do not have the wrap around closing piece. Need a photo really ! Lot easier. I have had a lot of LRs, but never an ex military series. AFAIK, I dont recall seeing anti burst locks on a Civvy series here. Early 90/110 anti burst lock striker - MRC8444 Quote Link to comment Share on other sites More sharing options...
smallfry Posted December 13, 2021 Share Posted December 13, 2021 Such a long time since I looked at them, but that looks something like it as far as I can remember. I do remember thinking that I would try to use the standard Defender type striker as an experiment. Not got round to it yet. Only been about ten years, you cant rush these things. Welding doesnt look great on the photo, does it ? When I go, I will get a couple of photos for you. Doors and strikers are not fitted to a vehicle though, so will not be clear about assembly order. 1 Quote Link to comment Share on other sites More sharing options...
uninformed Posted December 13, 2021 Author Share Posted December 13, 2021 57 minutes ago, smallfry said: Such a long time since I looked at them, but that looks something like it as far as I can remember. I do remember thinking that I would try to use the standard Defender type striker as an experiment. Not got round to it yet. Only been about ten years, you cant rush these things. Welding doesnt look great on the photo, does it ? When I go, I will get a couple of photos for you. Doors and strikers are not fitted to a vehicle though, so will not be clear about assembly order. Thanks mate. Quote Link to comment Share on other sites More sharing options...
Badger110 Posted December 14, 2021 Share Posted December 14, 2021 I fitted split doors with anti burst locks to my 2011 puma and had to order separate strikers as the puma doors use something completely different I ordered these strikers https://www.sp-4x4.com/product_p/fqb500170.htm Unfortunately no LR part number but eBay comes up with these https://www.ebay.co.uk/itm/193719745712?hash=item2d1a98bcb0:g:InUAAOSwAuRfkWOW LH - FQB500170 RH - FQB500160 1 Quote Link to comment Share on other sites More sharing options...
missingsid Posted December 15, 2021 Share Posted December 15, 2021 On 12/13/2021 at 12:24 AM, uninformed said: Early 90/110 anti burst lock striker - MRC8444 My S2 hybrid had those on the tub to match early 90/110 doors. Quote Link to comment Share on other sites More sharing options...
smallfry Posted December 22, 2021 Share Posted December 22, 2021 Here are the photos of my very early 110 doors and strikers. Sorry about the carp photos of the doors, they have been there for about 20 years, and since had a lathe put in front of them, and I was hanging over that, and a pillar drill. Doesnt show any detail of the lock itself unfortunately. 1 Quote Link to comment Share on other sites More sharing options...
uninformed Posted December 22, 2021 Author Share Posted December 22, 2021 12 minutes ago, smallfry said: Here are the photos of my very early 110 doors and strikers. Sorry about the carp photos of the doors, they have been there for about 20 years, and since had a lathe put in front of them, and I was hanging over that, and a pillar drill. Doesnt show any detail of the lock itself unfortunately. Thanks for updating. Land Rover bits, a lathe and pillar drill ….sounds like heaven to me 🙂 Quote Link to comment Share on other sites More sharing options...
smallfry Posted December 22, 2021 Share Posted December 22, 2021 3 hours ago, uninformed said: Thanks for updating. Land Rover bits, a lathe and pillar drill ….sounds like heaven to me 🙂 Not when you are climbing over them it isnt ! Luckily the milling machine is in the other corner ! Quote Link to comment Share on other sites More sharing options...
uninformed Posted December 25, 2021 Author Share Posted December 25, 2021 On 12/22/2021 at 11:11 PM, smallfry said: Not when you are climbing over them it isnt ! Luckily the milling machine is in the other corner ! Lol now you are just rubbing it in 🤪 1 Quote Link to comment Share on other sites More sharing options...
Bigj66 Posted December 28, 2021 Share Posted December 28, 2021 Paintman sell them. I fitted them to my S3 👍 Quote Link to comment Share on other sites More sharing options...
