Clutch damper issue
Jim Mason
Help...
Clutch slave damper seems to have failed or is blocked unable to get any fluid past it to bleed clutch, gravity bleeding is doing nowt.
Used my break bleeder to force fluid through but nothing is happening.
Does anyone have any ideas to resolve issue?
Replaced slave cylinder due to fluid found in bell housing when engine was removed, engine back in but now peddle on floor unable to bleed.
Bleed nipple is top facing, unsure what else to try...
Are you getting fluid from the Master Cylinder ?
Are you getting fluid pass the flexible bit ?
Are you getting fluid before the damper ?
You really need to start at the beginning and assume nothing..
As above, flexible pipe can degrade blocking fluid route, no obvious kinks or damage in pipework from engine removal , clutch fork ok not punched through ( it happens ) master cylinder seals ok and not bypassing, as Arjan says you need to do it in order to find where the issue is regards Stephen
Found this during an internet search, its got to be worth a try?
https://mtaeta.info/thread/2494/reverse-bleeding-clutch-system
Bleeding a clutch system in reverse if the conventional method is not working correctly.
This method has been ok on several occasions to bleed a clutch system where its been difficult to bleed it in the normal way.
Connect a pipe from brake caliper bleed nipple to bleed nipple for the clutch ,using the brake pedal pump the fluid so any trapped air will end up coming through to the master cylinder
Unless you have a device to bleed it that way !!just a tip and something to try
Done clutches and had a couple after a few days and the pedal has dropped,after bleeding them in reverse solved the problem.
  • Like 1
Are you reverse pressure bleeding - if not, it won't work. And you need to really bleed it through - about 500ml
The damper is essentially a deliberate air bubble in the system
Replacement with a 110/90 flexi pipe is the best way, but as they last so long when ste up correctly, it's a bit of a phaff.
13 hours ago, Jim Mason said:
Was going to reverse bleed, get fluid into all of the pipework using a clean pump and fresh fluid.
Then fill reservoir and gravity bleed.
Hopefully this should resolve all issues
Reverse bleed the only way to do it - and even dealer practice in the olden times
Then just top up the reservoir
  • 2 weeks later...
Are you able to pressure bleed downward through the system and get fluid expelled?  Seems like you still have air trapped somewhere.
Another possibility is a failed clutch fork.  Air in the system should still get a firmer pedal with a few rapid pumps.
Removed master cylinder, drained fluid out.
Took into kitchen filled reservoir with water and pushed piston in & out nothing was ejected out of master cylinder.
Looks 100% like its passing past the seals, stripped & nothing obvious no bits missing etc.20220116_134801.thumb.jpg.5aeec6bf75557dcae7389c49e729d9d5.jpg
21 hours ago, Jim Mason said:
Seem pretty hard to me, not seen new but as a hydraulic engineer i would not use them...
Fresh fluid instantly turned dark with silver particles...
Replacement is the way forward with this...
In the olden times I would have rebuilt a master cylinder or slave cylinder, now I'd just buy a new one. But onlt TRW or AP Lockheed
  • Like 1
