Will a LT85 go under a R380 tunnel ?
I may change the 300 Tdi with the R380 (Td5) for a Mazda that comes with the LT85
Are the gear levers in a totally different place or will I be able to re-use / modify the R380 (Td5) tunnel ?
Thank you.
  • Arjan changed the title to Will a LT85 go under a R380 tunnel ?
I have an LT85 in mine and it looks more or less the same. Maybe the tunnel moulding (its plastic or glassfibre) is a bit bigger as the LT85 is a bit more bulky ?
I think Miketomcat made one for someone a while ago. Might still have the mould. I imagine a "proper" one might be hard to get nowadays.
22 hours ago, Arjan said:
Thank you !!
Hope it fits - getting stuff from the UK is not as easy as it was....
You happy with the LT85 ?
Thank your government and the EU for that one ! Its not from this end. Politics. Arrrrrrrrgh !
LT85 ? Top gear is slightly lower than an R380/LT77, but with that engine I think you would want to change the transfer box ratio anyway.
They say its stronger, but I cannot vouch for that. It IS noisier, but the diesel will drown that out, and they tend to wear the shaft bearings a whine a bit.
Gearchange is fine for me, but then  I am used to driving heavier vehicles, dont notice
  • Haha 1
Goedeavond,
Sorry for the delay but I'm en route.
You're an ACE !!!!!
Please let me know what sort of money you'd like for it - and would you be willing to post it towards Bristol ?
I'll be in the UK it seems later this year but with a 18 tonnes truck so detouring is not easy....
Again, many thanks !!
It’s I. The for sale section
 price wise I don’t mind really. Was trying to see what it was worth but if you need one cover postage and give some money to the forum ?  There is a nimble in it so check the description.
