Stellaghost Posted November 28, 2022 Share Posted November 28, 2022 9 minutes ago, The_rayess said: I will grease it for sure but what do you mean by get a boot for it ? The boot is a rubber cover that protects the sliding joint from mud and dust, think shock absorber boot and you will get the idea regards Stephen Quote Link to comment Share on other sites More sharing options...
Gazzar Posted November 28, 2022 Share Posted November 28, 2022 This. Quote Link to comment Share on other sites More sharing options...
The_rayess Posted November 28, 2022 Author Share Posted November 28, 2022 52 minutes ago, Stellaghost said: The boot is a rubber cover that protects the sliding joint from mud and dust, think shock absorber boot and you will get the idea regards Stephen Aha yes i know the shock absorber boot ! But never think about puting it on a driveshaft thats a good idea 🙏 Quote Link to comment Share on other sites More sharing options...
The_rayess Posted November 28, 2022 Author Share Posted November 28, 2022 15 minutes ago, Gazzar said: This. Thank you ! Do you k ow whats the minimum length of the driveshaft can be ? Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted November 28, 2022 Share Posted November 28, 2022 5 minutes ago, The_rayess said: Aha yes i know the shock absorber boot ! But never think about puting it on a driveshaft thats a good idea 🙏 Not quite, you can buy short versions that are made specifically for prop shaft sliding joints regards Stephen Quote Link to comment Share on other sites More sharing options...
Gazzar Posted November 28, 2022 Share Posted November 28, 2022 Take off the propshaft. Compress, CAREFULLY, the axle against the bump stops. Completely. Measure from the centre of the transfer box to the center of the axle drive flange. That distance, less, maybe, 10 mm, to allow for the gearbox moving on the mountings. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted November 28, 2022 Share Posted November 28, 2022 9 minutes ago, The_rayess said: Thank you ! Do you k ow whats the minimum length of the driveshaft can be ? Don't know the absolute minimum length, but you could go down to around 300mm, but it depends upon how much suspension travel you have, if you have a lot you would be better off with a wide angle propshaft regards Stephen Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 28, 2022 Share Posted November 28, 2022 My rear prop is 360mm withbroom to go shorter according to the manufacturer (was a custom made prop). But that is the more compact LR yokes, your Toyota ones are much longer and I doubt you will get much shorter than that. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 28, 2022 Share Posted November 28, 2022 P.s. the Toyota props are well known to be very wide angle, so no problem there. 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted November 28, 2022 Share Posted November 28, 2022 1 minute ago, Bowie69 said: P.s. the Toyota props are well known to be very wide angle, so no problem there. Didn't know that Thank you regards Stephen Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted November 28, 2022 Share Posted November 28, 2022 9 minutes ago, Stellaghost said: Didn't know that Thank you regards Stephen Yet another reason why the yanks love toyota 'mini-trucks' for rock crawlers. Quote Link to comment Share on other sites More sharing options...
steve b Posted November 28, 2022 Share Posted November 28, 2022 1 hour ago, The_rayess said: Yes i will change it for sure! Yes i drilled the flange on the transfer case ! Whats the shortest driveshaft i can use in length ? The Land Rover prop has a raised ring (spigot ring) on the bolt face to the TB flanges. This is a close fit, do the toyota props have this? Without it the prop will not run on centre and will vibrate the hell out of things. Steve Quote Link to comment Share on other sites More sharing options...
The_rayess Posted November 28, 2022 Author Share Posted November 28, 2022 27 minutes ago, Bowie69 said: P.s. the Toyota props are well known to be very wide angle, so no problem there. Yes i dont have problem with angles ! Its fine ! I think my problem with the length of the driveshaft ! Its like arrives to stop no more sliding in ! It should be shorter i think tomorrow i will make measurements! Quote Link to comment Share on other sites More sharing options...
The_rayess Posted November 28, 2022 Author Share Posted November 28, 2022 3 minutes ago, steve b said: The Land Rover prop has a raised ring (spigot ring) on the bolt face to the TB flanges. This is a close fit, do the toyota props have this? Without it the prop will not run on centre and will vibrate the hell out of things. Steve Yes toyota also have it ! Quote Link to comment Share on other sites More sharing options...
The_rayess Posted November 28, 2022 Author Share Posted November 28, 2022 2 hours ago, Gazzar said: Take off the propshaft. Compress, CAREFULLY, the axle against the bump stops. Completely. Measure from the centre of the transfer box to the center of the axle drive flange. That distance, less, maybe, 10 mm, to allow for the gearbox moving on the mountings. I will do it tomorrow thank you 🙏 Quote Link to comment Share on other sites More sharing options...
The_rayess Posted November 28, 2022 Author Share Posted November 28, 2022 43 minutes ago, Stellaghost said: Not quite, you can buy short versions that are made specifically for prop shaft sliding joints regards Stephen I will ask about it Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 28, 2022 Share Posted November 28, 2022 29 minutes ago, The_rayess said: Yes toyota also have it ! Is it a good fit to the land rover flange? It's got to be a good fit otherwise its as good as not having it. Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 28, 2022 Share Posted November 28, 2022 For the boot, I prefer to go without unless it's designed for it. But just grease regularly to keep the carp out. Quote Link to comment Share on other sites More sharing options...
The_rayess Posted November 28, 2022 Author Share Posted November 28, 2022 12 minutes ago, landroversforever said: Is it a good fit to the land rover flange? It's got to be a good fit otherwise its as good as not having it. I made one in my friend shop specially for the yota driveshaft so i can keep it ! 1 Quote Link to comment Share on other sites More sharing options...
The_rayess Posted November 28, 2022 Author Share Posted November 28, 2022 Thanks everyone for the help I appreciate it guys 🙏 Quote Link to comment Share on other sites More sharing options...
The_rayess Posted November 29, 2022 Author Share Posted November 29, 2022 Today i will be shortening my driveshaft and replacing u joint Quote Link to comment Share on other sites More sharing options...
landroversforever Posted November 29, 2022 Share Posted November 29, 2022 32 minutes ago, The_rayess said: Today i will be shortening my driveshaft and replacing u joint Not sure how the toyota props differ, but make sure the UJs are phased correctly for the application. The prop should also probably be re-balanced. Quote Link to comment Share on other sites More sharing options...
The_rayess Posted November 29, 2022 Author Share Posted November 29, 2022 10 hours ago, landroversforever said: Not sure how the toyota props differ, but make sure the UJs are phased correctly for the application. The prop should also probably be re-balanced. Yes i rebalanced it ! And change 1 uj i noticed the other one have slightly movement maybe i will re change it but now the sound is almost gone i think 1 Quote Link to comment Share on other sites More sharing options...
