Gazzar Posted March 14 Author Share Posted March 14 Ideally, replace. If you can find one. Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 14 Share Posted March 14 That does mostly look ok, but the lay shaft should not be run in that condition. Have a word with Nige (hybrid from hell) - he might be able to make it serviceable with some treatment in his polishing machine. I think it’ll howl, whatever you do with it. A replacement would be best, if you can find one. I suspect a ball bearing escaped a race and did all that damage. Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 14 Share Posted March 14 4 minutes ago, Snagger said: Have a word with Nige (hybrid from hell) Literally the other side of the world! Quote Link to comment Share on other sites More sharing options...
Snagger Posted March 14 Share Posted March 14 I missed that. Must be some more local gear specialists that can do the same process. If not, freight is a thing… Quote Link to comment Share on other sites More sharing options...
Dan John Posted March 14 Share Posted March 14 It seems that all these overdrives fail re the input gear and layshaft? All parts are available except those. And the clutch sleeve... I'll look at options re the layshaft. They seem even harder to find than the input gear? I guess I can use it if desperate, despite the noise. It's the risk of it being too weak, and stripping teeth, that worries me. And if I'm fortunate enough to find an input gear, would hate for layshaft to damage it. I'll follow up your suggestion re Nige. Looking at the circular chips, it would certainly seem like a ball has done that damage. Just not sure from where as from what I can see, the only ball bearing is the really big one behind input gear. 1 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 14 Author Share Posted March 14 Yep, I found a guy who used to make the layshaft and input gears, but he's retired. Evolution/heritage aka Craig Cunningham used to get a lot of bits made, but his supplier went bust, and the specifications were lost. Not looking good for older Landrovers at the moment. Quote Link to comment Share on other sites More sharing options...
Dan John Posted March 14 Share Posted March 14 No, it isn't. I'll look into what can be done with my laygear. Between that and there hopefully being a usable input gear in your spares, I might at least be able to get the thing operational. The cost of having new gears made would be, I beleive, prohibitive. More, probably, than what that lovely planetary gear OD from Australia would cost. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 14 Author Share Posted March 14 I was quoted £600 for one laygear. Quote Link to comment Share on other sites More sharing options...
Dan John Posted March 15 Share Posted March 15 Not surprising. I think I'll just have to use my laygear as it is, maybe get it cleaned up a bit, at best. My understanding is you may have a spare input gear, but definitely not laygear... If my laygear were all chipped the OD would be rubbish I'd say. Wish I could afford that Australian one. Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 15 Author Share Posted March 15 Every now and then I think about making one of these from new. Then I remember I'm broke and have no engineering skill.... Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted March 15 Share Posted March 15 2 minutes ago, Gazzar said: have no engineering skill.... That is not exactly true, is it? Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 15 Author Share Posted March 15 It's true. Sure: I can design and fabricate a bracket, or figure out if something will break, probably. But when it comes to helical gears, I couldn't probably even draw one anymore. Two years of tech drawing at secondary school does NOT an engineer make. Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted March 15 Share Posted March 15 2 hours ago, Gazzar said: Two years of tech drawing at secondary school does NOT an engineer make. That will be me screwed as well... Regards Stephen Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 15 Author Share Posted March 15 I beg to differ. I suspect you've more hands on experience than I do. I spend far too much time polishing a chair for a living ...... Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 15 Author Share Posted March 15 Anyway, I'm off to get another overdrive tomorrow. If this is junk then I'll put in the best layshaft I've got and call it done. 1 Quote Link to comment Share on other sites More sharing options...
Dan John Posted March 15 Share Posted March 15 Join the club guys. I too have dreams of doing this, doing that. And then money, and time, neither of which there is much of, dictate otherwise. I'm going to run thd layshaft I have, of I have too. It's probably sbout the same as the one you have there, Gazzar. So I'd think you'll get away with it. As Snaggar wisely says, have spares on hand 24/7 lol Fingers crossed that OD you're collecting has the goods you need. Here's the old girl mine is going in... 1 Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted March 15 Share Posted March 15 2 hours ago, Gazzar said: I spend far too much time polishing a chair for a living ...... That may be so......however from what I'm witnessing, you have great skills / knowledge I know some so called engineers that don't have a patch on you.......truly Regards Stephen Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted March 15 Share Posted March 15 11 minutes ago, Dan John said: Join the club guys. I too have dreams of doing this, doing that. And then money, and time, neither of which there is much of, dictate otherwise. I'm going to run thd layshaft I have, of I have too. It's probably sbout the same as the one you have there, Gazzar. So I'd think you'll get away with it. As Snaggar wisely says, have spares on hand 24/7 lol Fingers crossed that OD you're collecting has the goods you need. Here's the old girl mine is going in... That's a nice tidy looking truck Regards Stephen 1 Quote Link to comment Share on other sites More sharing options...
Dan John Posted March 15 Share Posted March 15 18 minutes ago, Stellaghost said: That's a nice tidy looking truck Regards Stephen Cheers Stephen Definitely been built on a budget - painted myself etc. But really happy with it. 1 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 16 Author Share Posted March 16 @Dan John That, sure, is a credit to you. I really like the tray back, such a practical configuration. 1 Quote Link to comment Share on other sites More sharing options...
Dan John Posted March 16 Share Posted March 16 Thank you. I've had probably 10 different landies over the years. Still own the first one I built, as a teenager. Not road worthy, but in good nick. Painted it with a brush and house paint! I'd love to see yours - a 101 I beleive? Very few of those over here. Great axles in those things! Salisbury up front as well? Quote Link to comment Share on other sites More sharing options...
Dan John Posted March 16 Share Posted March 16 1 Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 16 Author Share Posted March 16 Mine. https://forums.lr4x4.com/topic/112435-101-what-have-i-done/#comments https://forums.lr4x4.com/topic/103512-stories-of-oakie-a-series-about-a-series/#comments Quote Link to comment Share on other sites More sharing options...
Gazzar Posted March 16 Author Share Posted March 16 Yet another overdrive. I'll strip this Monday morning, see what I've got. It does turn. And very little play.... 1 Quote Link to comment Share on other sites More sharing options...
Dan John Posted March 17 Share Posted March 17 15 hours ago, Gazzar said: Yet another overdrive. I'll strip this Monday morning, see what I've got. It does turn. And very little play.... It's a nervous wait! All the best. Thanks for the link to the build thread, Gazzar. I'll read with interest. Ah, yes, bees. I recently went to look at a safari body, only to find I couldn't get near it due to the nest of hornets living in between the main roof and safari skin! Quote Link to comment Share on other sites More sharing options...
