LT 95 Fairey overdrive (Devon) reconditioning
Gazzar
That is almost identical configuration to the Series version.
When you put it all back together, it’s a swine to get the lay shaft cluster into place but offset without the shaft itself while you fit the main shaft stuff.  Use a screw driver or any thinner shaft through the cluster and bearings to keep them in a position that you can manipulative them for alignment later - use the smaller shaft or tool to stir the bearings into alignment with the casing bores.
  • Like 1
Never opened a series one, but I'm told these are tougher. One difference is better lubrication, there's two drillings from the transfer box so they share the lubrication.
I'm going to clean this all up during the week, and hopefully rebuild next weekend. Other things on, which may interfere. But for now I've an 88" I need to assist on.
  • Like 1
Thanks, not deserved. As someone who just put the short drive shaft into the long side of the axle casing, and didn't spot it, NOT deserved.  I'm not entirely with it mentally, and already planning to redo some work as I'm not happy with it...
Your too hard on yourself at times
I stand by what I posted..
Regards Stephen
  • Like 1
I would expect them to be a flair bit tougher to handle the V8 rather than 2.25.  There is no similar oil path on the Series version.  But the general configuration is very similar, the differences seemingly dimensions and probably material specs for the most part.  Then again, why reinvent the wheel?  Roverdrives are pretty similar between their models, but with differences where needed.  I suspect they even share some common parts.
I had a very low mileage series overdrive, with known history, and a second horribly neglected one with very worn gear teeth / failed bearings etc. I rebuilt the neglected one out of curiosity with all new bearings but retaining the worn gears as wasn’t worth spending any money on it, I swapped it into my series and it sounded no worse than the very low mileage one when in use!
  • Like 1
Detail difference on the different castings.
The scrap casing has a square headed second plug, compared to the good casing, which has a hex head plug
Different thread, too. Is this a rationalisation measure?
If you don’t mind spending the cost of the bearings, there is little to be lost by trying.
Faireys do tend to howl, even brand new.  That is less of a concern than rapid wear and failure because of the teeth having worn through their hardening.  I think that the unit I rebuilt last year was in that category - some of you reinforced that suspicion when I shared photos of the wrecked gears (lay shaft cluster and input gear at the back of the main shaft).  If you replace gears, then you really want to be confident that the rest of the parts are worth the investment - the gears are costly if you can find them.
Any sign of cross-threading in either casing?  Could just be a lost plug was replaced with whatever came to hand.
It may be best having the casings vapour blast.  That’ll bring them up like new and will also peen the surface to reduce future dirt and corrosion marking.  It’ll be a lot faster than other methods, too.  I doubt the ultrasonic will shift the staining.
I've sourced a new lay gear set, and will fit the best of what I've got to one, and have the other on the shelf as a spare.
  • Like 1
My vapour blast contact sold his equipment, not doing it anymore. If it's not clean enough, I'll paint it with 2k silver.
  • Like 1
