Stellaghost Posted February 21 Share Posted February 21 Started Sid this morning for the first time in ages, engine sounded fine. Whilst ticking over I noticed water falling so went to investigate and found these on the floor Two core plugs have come out.... I can only assume its been cold enough to freeze the water in the block and popped the core plugs Does emphasise how important antifreeze mix is... Regards Stephen 2 1 Quote Link to comment Share on other sites More sharing options...
elbekko Posted February 21 Share Posted February 21 I hope the freeze plugs popping out is all that happened, my 300TDi didn't like freezing and cracked the block... 1 1 Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted February 21 Share Posted February 21 He's not keeping that engine for long anyway 😜 But yes, I have had that before, alarming, and a good warning to make sure you have 50% coolant mix in there... Quote Link to comment Share on other sites More sharing options...
Stellaghost Posted February 21 Author Share Posted February 21 2 minutes ago, Bowie69 said: He's not keeping that engine for long anyway 😜 Correct.........need to get my finger out..... Regards Stephen Quote Link to comment Share on other sites More sharing options...
steve b Posted February 21 Share Posted February 21 ...no point in putting new ones in , just rip the engine out and bin the exhaust. Drain the tank and refill with the correct fuel If the block is cracked it's usually along the section directly under the manifolds. Steve Quote Link to comment Share on other sites More sharing options...
miketomcat Posted February 21 Share Posted February 21 I had this on 45 fitted new core plugs re filled with water (+more antifreeze this time) and carried on. In fact that block is the one in the ibex at the moment. Mike 1 Quote Link to comment Share on other sites More sharing options...
Nonimouse Posted February 22 Share Posted February 22 Nice that they are doing there job. I've started fitting brass core plugs (marine use) to engines I work on. They look nicer 1 Quote Link to comment Share on other sites More sharing options...
