fearofweapons Posted July 30 Share Posted July 30 The two washers, 13 and 12 in the diagram below, have a flat and a rounded side. Which side should go against the bushing ( 15 )? When I took mine off to replace them there were no washers present - 😮😭 Quote Link to comment Share on other sites More sharing options...
Junglie Posted July 30 Share Posted July 30 I think by default flats against the bush. But I may be wrong (50/50 chance I guess) Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 30 Share Posted July 30 Round to the bush. That said, some aftermarket shocks don't use them Quote Link to comment Share on other sites More sharing options...
Retroanaconda Posted July 30 Share Posted July 30 Round side to the bush to allow movement/flex in the shock. 2 Quote Link to comment Share on other sites More sharing options...
fearofweapons Posted July 30 Author Share Posted July 30 Thanks gents. Without the washers the nut will not do up tight against the bush, so it will 'slop' about on the pin without them. As for domed or flat side against the bush - still non the wiser as two conflicting answers............ Quote Link to comment Share on other sites More sharing options...
Bowie69 Posted July 30 Share Posted July 30 Round to bush is what we both said Quote Link to comment Share on other sites More sharing options...
bishbosh Posted July 30 Share Posted July 30 Definitely round to the bush - imaging the movement of the shck as the axle cycles - the head of the shock needs to rotate about an axis perpendicular to the mount (by deforming the bush). If you want to snap the head off the shock put the flat side against it and do the bolt up tight. 1 Quote Link to comment Share on other sites More sharing options...
Junglie Posted August 1 Share Posted August 1 I was wrong - just took my rears off. Round to the bush, so no conflicting answer. Sorry for the confusion. Quote Link to comment Share on other sites More sharing options...
Junglie Posted August 1 Share Posted August 1 On 7/30/2024 at 4:27 PM, bishbosh said: Definitely round to the bush - imaging the movement of the shck as the axle cycles - the head of the shock needs to rotate about an axis perpendicular to the mount (by deforming the bush). If you want to snap the head off the shock put the flat side against it and do the bolt up tight. That's actually really useful. I couldn't for the life of me make the logic jump as to why it wouldn't be flat against the bush... 1 Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted August 1 Share Posted August 1 Where's @steve200TDi's video of the shock mount flexing off-road? That's very illustrative. Quote Link to comment Share on other sites More sharing options...
steve200TDi Posted August 1 Share Posted August 1 That'll be this vidoo then: Steve 2 Quote Link to comment Share on other sites More sharing options...
Junglie Posted August 1 Share Posted August 1 Crikey. That's certainly illustrative... Quote Link to comment Share on other sites More sharing options...
