Jon W Posted March 2, 2007 Share Posted March 2, 2007 I have been told that these have larger yokes and so are wider angle. So if someone knows the part number, that will help me with my search for a price. Thanks Jon Quote Link to comment Share on other sites More sharing options...
SteveG Posted March 3, 2007 Share Posted March 3, 2007 Hi Jon just looked it up on the Mansfield Motors site shows an all makes one for 80 pounds. Give them a call and they'll give you LR part no. and cost, their tel no. 01284 767174 Cheers Steve Quote Link to comment Share on other sites More sharing options...
white90 Posted March 3, 2007 Share Posted March 3, 2007 Jon I think the rear TD5 prop is the same as the TDI one FRC83932 the only variant is the FRC8392 as fitted to drum, braked 90s the front has the larger UJs as discussed elsewhere. Quote Link to comment Share on other sites More sharing options...
BogMonster Posted March 3, 2007 Share Posted March 3, 2007 don't think so... new (post 2002) front propshafts have bigger UJs but I don't know if they are a wider angle but in a curious decision LR stuck with the same UJs on the back and to my eye the prop on my 90 looks the same as they always did? Quote Link to comment Share on other sites More sharing options...
Jon W Posted March 3, 2007 Author Share Posted March 3, 2007 Ah right I miss understood, or confused everyone. I need a new rear propshaft, but it seems it is only the front propshafts that have changed on TD5's. I will probably just go for a standard rear propshaft as can't justify the cost of a wide angle propshaft at the moment and I can't see myself spending more money on suspension mods for quite a long time. Thanks Jon Quote Link to comment Share on other sites More sharing options...
SteveG Posted March 3, 2007 Share Posted March 3, 2007 no it was duff information from us Jon. I just assumed as they had put a wider yoke on front they would have done the same on the rear. As Tony says rear is same for 300TDI and TD5 Cheers Steve Quote Link to comment Share on other sites More sharing options...
white90 Posted March 3, 2007 Share Posted March 3, 2007 Stephen fronts are definatley wider angle I had one side by side with the orig front one previously when I got a new one. Jon if you keep with a standard then you'll ruin the UJs on a new one too with the amount of travel you have. you'd better invest in a wide angled variant IMHO Quote Link to comment Share on other sites More sharing options...
darthdicky Posted March 8, 2007 Share Posted March 8, 2007 I think Jonathan's getting a wide angle one made up from the Propshaft clinic now, hopefully that'll sort it. Not sure whether the yokes do touch but I think it's been through a few UJ's and it has always been at the same end so it could well be the problem. Richard Quote Link to comment Share on other sites More sharing options...
western Posted March 9, 2007 Share Posted March 9, 2007 Td5 rear prop for 90 is FRC8393 from chassis number MA939976 also used on V8 90's. Quote Link to comment Share on other sites More sharing options...
