engine temp
gelf
ive just fiitted a new water temp guage in the disco......marked in oC.
runs at 55oC at normal running and just over 60oC when pushed.
just thought this seems a little low???
just checking to see what you think.
graham
the proper temp guage in the disco dash always runs a tiny bit over quarter..........if thats of any use.
Is that right? Mine has always been at just less than half way....
The only time it went over was just before steam came out from under the bonnet!
Mine also seems to run just under the half way mark pretty much regardless of how hard I work it and how hot the day is.
Pete.
