TJ101 Posted April 18, 2007 Share Posted April 18, 2007 Guys, only quick one, Books says sae 30 oil, is this what everyone else is using ??? and 6 oz of it ! how full should it be ? A quick search through the archives does not reveal a answer !! Also, should the mainshaft oil seal pop out the casing as easily as mine, or 1 do you seal them in ? 2 or have i not got mine in far enough ? Also, in the Gen brake kit, their is a "cardboard" ring, which goes between the casing and the brake drum, if this the bit that keeps the oil seal in ?? if so, its too wide, ?? TIA Quote Link to comment Share on other sites More sharing options...
pugwash Posted April 18, 2007 Share Posted April 18, 2007 whats an 8275? is it one better than an 8274? have you upgraded to a winch that actually works and doesn't smoke at the first hint of strain? Quote Link to comment Share on other sites More sharing options...
white90 Posted April 18, 2007 Share Posted April 18, 2007 Guys, only quick one, Books says sae 30 oil, is this what everyone else is using ??? and 6 oz of it ! how full should it be ?A quick search through the archives does not reveal a answer !! Also, should the mainshaft oil seal pop out the casing as easily as mine, or 1 do you seal them in ? 2 or have i not got mine in far enough ? Also, in the Gen brake kit, their is a "cardboard" ring, which goes between the casing and the brake drum, if this the bit that keeps the oil seal in ?? if so, its too wide, ?? TIA Mole Valley farmer sell SAE30 Tim in 5 litres containers put in a normal sized mug full and no more , or it'll leak Quote Link to comment Share on other sites More sharing options...
Les Brock Posted April 18, 2007 Share Posted April 18, 2007 From Mr Ciderman on my thread... Ok back on topic Les , Get a new Bronze bush , if its still a bit loose loctite it in and the seal , Drill 3 x2.5mm holes in a triangular format into the flange on the casing next to the seal tap them out with a 4mm tap screw in 3 M4x 5mm setscrews with washers that overlap the metal part of the seal , This will stop any float by the seal and bush . HTH Quote Link to comment Share on other sites More sharing options...
Petergg Posted April 18, 2007 Share Posted April 18, 2007 The seal should not pop out without a fight, it should be flush with casing, 200ml oil I use ep80/90. Peter Quote Link to comment Share on other sites More sharing options...
TJ101 Posted April 18, 2007 Author Share Posted April 18, 2007 whats an 8275? is it one better than an 8274? have you upgraded to a winch that actually works and doesn't smoke at the first hint of strain? What you on Jim ??? ( thanks Mod ) Mm, 30 or 80/90 , got gallons of that, even fully synthetic 85/90, Les, yep, new bush and seal, will try the loctite Quote Link to comment Share on other sites More sharing options...
Les Brock Posted April 18, 2007 Share Posted April 18, 2007 Slightly off topic but related.... In the brake kit there is a Round "thing" with a small section cut out... Where does that go then ? I ask because the one 8274 I got from Steve was in bits already and the other one did'nt have one when I stripped it down, both are old, with the round free spool knob, and the brake and the brake assembly you could pull 1/2" out from the main body, athough the seal and bush were about as loose as you could get also if I needd them better get them ordered as I want to try and get them both back together this weekend Quote Link to comment Share on other sites More sharing options...
TJ101 Posted April 18, 2007 Author Share Posted April 18, 2007 Slightly off topic but related....In the brake kit there is a Round "thing" with a small section cut out... Les,, that sounds like the "cardboard" thing i was on about,, According to the drawings, it goes between the seal/bush etc on the mainshaft, and the brake drum, In my case, if you fit it, the mainsahft does not push fully back in, for the lock plate to located in the gear-case top !! Quote Link to comment Share on other sites More sharing options...
yella 90 Posted April 18, 2007 Share Posted April 18, 2007 the cordboard washer thing is a spacer afink to set the right depth of the bush back in, but i stand corrected i never use it anyhows it does mention it somewhere in the destructions that come with the service kit o i run mine 8274's on cv grease runs quieter dan Quote Link to comment Share on other sites More sharing options...
white90 Posted April 18, 2007 Share Posted April 18, 2007 Dan any signs of gear wear? the lubrication is just splash and the CV grease needs warming up to get thin what was the reason for going to Grease? Ta Tony Quote Link to comment Share on other sites More sharing options...
JST Posted April 18, 2007 Share Posted April 18, 2007 Tim, ditch the cardboard. Quote Link to comment Share on other sites More sharing options...
gsr341 Posted April 18, 2007 Share Posted April 18, 2007 card board not menat to stay in its to push the seal in to the casing , got the fitting instructions here some where want me to scan and post them ? Quote Link to comment Share on other sites More sharing options...
RedLineMike Posted April 18, 2007 Share Posted April 18, 2007 just finished building my 8274 for going on my 90 & i contacted a well know supplier & tweaker of 82's & they said to put ATF in it so thats what mine got, Quote Link to comment Share on other sites More sharing options...
TJ101 Posted April 18, 2007 Author Share Posted April 18, 2007 Ok, so far we have CV Grease Sae 30 EP 80/90 ATF Think i am going to try the synthetic 85/90 !!, Loctite the seal/bush, after using the cardboard ring to push home as far as possible !! Quote Link to comment Share on other sites More sharing options...
Guest WALFY Posted April 18, 2007 Share Posted April 18, 2007 Tim Give Gigglepin a call. Spk to Jim he knows everything there is to know. 01732463600 Quote Link to comment Share on other sites More sharing options...
white90 Posted April 18, 2007 Share Posted April 18, 2007 SAE30 is the manufactures spec so that's what I use it also says non detergent in the manual. Quote Link to comment Share on other sites More sharing options...
Ex Member Posted April 18, 2007 Share Posted April 18, 2007 I use a low viscosity gear oil. Same viscosity as the 30 weight (basically) but better for gear life and stays fluid at cold temperatures (unlike straight 30 weight). Normal gear oil would probably eat a bit of power. Quote Link to comment Share on other sites More sharing options...
Tonk Posted April 19, 2007 Share Posted April 19, 2007 all i've ever used is engine oil, so 10/40 or 15/40, never any probs or wear Quote Link to comment Share on other sites More sharing options...
yella 90 Posted April 19, 2007 Share Posted April 19, 2007 no signs of ware tony, i prefere it cos it just sticks to everything and lubs well IMO, the cam stays well greasy its even worked its way into the bronze bushes which i couldnt believe, at 1st it was only tempp to see what they run like, but now its perminant as for servicing, both mine are accessed very easy so i remove them strip, put in parts washer ect just abit messier thats all dan Quote Link to comment Share on other sites More sharing options...
white90 Posted April 19, 2007 Share Posted April 19, 2007 Sounds like a good mod then Quote Link to comment Share on other sites More sharing options...
yella 90 Posted April 19, 2007 Share Posted April 19, 2007 use 1 tube and its just right, turn the drum by hand and watch it cling to everything it touches, another thing i found it that all the bits that find themselve at the bottom get flung up in the grease then stick to the top casing so you can wipe it out easily dan Quote Link to comment Share on other sites More sharing options...
