nickm Posted May 31, 2007 Share Posted May 31, 2007 has anyone had a jingle'ing noise that sounds astho you have a chain dragging along the floor ? sounds astho its from the front end or the bellhousing (maunual 200tdi rangey runninggear) Quote Link to comment Share on other sites More sharing options...
simonr Posted May 31, 2007 Share Posted May 31, 2007 has anyone had a jingle'ing noise that sounds astho you have a chain dragging along the floor ?sounds astho its from the front end or the bellhousing (maunual 200tdi rangey runninggear) Check the washers on your hockey stick chassis end bushes. When the nuts are loose, the wasjers make that kind of noise. Si Quote Link to comment Share on other sites More sharing options...
Nigel H Posted May 31, 2007 Share Posted May 31, 2007 has anyone had a jingle'ing noise that sounds astho you have a chain dragging along the floor ?sounds astho its from the front end or the bellhousing (maunual 200tdi rangey runninggear) Check the aluminium cover on the alternator, these often wear through the bolts. Also, any heat shields you may have on the exhaust. Both can cause a "jingle'ing". N. Quote Link to comment Share on other sites More sharing options...
reads90 Posted May 31, 2007 Share Posted May 31, 2007 Check the aluminium cover on the alternator, these often wear through the bolts. Also, any heat shields you may have on the exhaust. Both can cause a "jingle'ing".N. Yeah i would check with what Nigel said Even if it does seem rather tech from Nigel , Hey mate is that all your own work or you asking the person sat across the desk from you Just when i asked him for his opion on the same question about my V8 last weekend he told me the same ans as you . Quote Link to comment Share on other sites More sharing options...
simonr Posted May 31, 2007 Share Posted May 31, 2007 Check the aluminium cover on the alternator, these often wear through the bolts. Also, any heat shields you may have on the exhaust. Both can cause a "jingle'ing".N. And, come to think of it, the cooling turbine on the front of the alternator hitting something else.. Si Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted May 31, 2007 Share Posted May 31, 2007 rattly bits in the clutch? broken fingers or such? maybe you should check your towbar for a wayward piece of chain... Quote Link to comment Share on other sites More sharing options...
nickm Posted May 31, 2007 Author Share Posted May 31, 2007 mmm i was also thinking about the clutch always works ok tho does seem to mainly do it after its been standing for a while already binned all of the heat shields will check the front radius arms and the alternator sure the only thing that could hit is the pipe to the intercooler cheers Quote Link to comment Share on other sites More sharing options...
JST Posted May 31, 2007 Share Posted May 31, 2007 mine does this as well and has since i bought it. its not the radius arm washers (i doesn't have any) nor shields etc. i also reckon its clutch area related but it all works so i have typically just left it!!!! it does it on coasting/over run mainly cluth in and out both in and out of gear. 200tdi as well. Quote Link to comment Share on other sites More sharing options...
jjojjas Posted May 31, 2007 Share Posted May 31, 2007 mine did this and I traced it to the alternator. Sprayed a bit wd40 on it when it was running and it went away....no ide what it was! Quote Link to comment Share on other sites More sharing options...
Beast5680 Posted May 31, 2007 Share Posted May 31, 2007 i,ve just had this very same noise appear on a disco i have and i managed to finally track it down after driving me mad, the pins holding the front brake pads appear to have no anti rattle springs on them which was making them jingle as i drove along Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted May 31, 2007 Share Posted May 31, 2007 As Simon said above, check the alternator fan. I had one of the long bolts come undone on the alternator which would slide in and out kissing the fan on the end of it's travel and giving a very loud intermittent jingling ! Mo Quote Link to comment Share on other sites More sharing options...
rtbarton Posted May 31, 2007 Share Posted May 31, 2007 If it changes with vehicle speed (rather than engine speed) it could be a universal joint. Clean the muck off the spiders and look for bright shiny metal and rusty dust round the spider journals. Quote Link to comment Share on other sites More sharing options...
Nigel H Posted May 31, 2007 Share Posted May 31, 2007 Yeah i would check with what Nigel saidEven if it does seem rather tech from Nigel , Hey mate is that all your own work or you asking the person sat across the desk from you Just when i asked him for his opion on the same question about my V8 last weekend he told me the same ans as you . Cheeky Mare! All my own work, had problems with the wafer thin alt covers before, having to pad the holes out with with washers. I have learnt a few things a long the way. And I have my own office - Jules f@rts to much to share with anyone. Quote Link to comment Share on other sites More sharing options...
landmannnn Posted May 31, 2007 Share Posted May 31, 2007 Check your propshaft bolts are not loose. Once had loose rears which made the handbrake drum jingle. Quote Link to comment Share on other sites More sharing options...
