JST Posted June 26, 2007 Share Posted June 26, 2007 anyone done the conversion on here???? if so any difference in outlet temp? how did they fit it? pipe work wise. - just thinking..... Quote Link to comment Share on other sites More sharing options...
poacher Posted June 26, 2007 Share Posted June 26, 2007 Seen a few done but to be honest, with the length of pipes that have to run behind the radiator - is it worth it? Would be better off bonnet mounted or at least sat above the turbo. We did fit a pair of electric fans behind a TD5 radiator, not much difference but did give the same effect in the cab as it would if you had aircon running???? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 26, 2007 Share Posted June 26, 2007 waste of time I would have thought, easier to get a proper upgraded one with the pipes on the right side of the engine bay Quote Link to comment Share on other sites More sharing options...
JST Posted June 26, 2007 Author Share Posted June 26, 2007 thats what i was thinking, but i suppose you could change one end of the td5 intercooler so it connected say downwards then run pipe across the front. Does anyone know the air cooling rates for std tdi 'improved flow tdi' td5 std or know where you can get them? Quote Link to comment Share on other sites More sharing options...
white90 Posted June 26, 2007 Share Posted June 26, 2007 you could put a thermocouple in each side to check the cooling efficiency you should look for 30degrees drop across the core to be efficient. if you fancy a new intercooler I'd recommend Brunel Quote Link to comment Share on other sites More sharing options...
JST Posted June 26, 2007 Author Share Posted June 26, 2007 i came to the conclusion Brunel were the way fwd when i last looked into this so thats an option but looking for a cheap ££££ as now have a spare td5 and tdi intercooler to play with. could a rad repairers change the ends on an intercooler? Quote Link to comment Share on other sites More sharing options...
BigSi110 Posted June 27, 2007 Share Posted June 27, 2007 So you've got a Td5 intercooler lying around. Why not sell that and the Tdi unit and use the money towards a new Brunel unit? I've just ordered my new intercooler from Jon at Brunel. He''l be fitting it at Billing, so I'll report back afterwards. I'd imagine a rad repairer would do the ends on an intercooler. Or a decent metal fabricator. Quote Link to comment Share on other sites More sharing options...
Lewis Posted June 27, 2007 Share Posted June 27, 2007 Mount it on its side so that the inlet and outlet are in the right place for a tdi? Use a saab cooler and suffer the longer pipes? Lewis Quote Link to comment Share on other sites More sharing options...
poacher Posted June 27, 2007 Share Posted June 27, 2007 Or by a Twisted Performance one, not that bad. I've seen a post somewhere about putting in/out at the correct side of the cooler, just can't remember where. Quote Link to comment Share on other sites More sharing options...
Mark Posted June 27, 2007 Share Posted June 27, 2007 Les did this to a 200 tdi disco one to fit into catflap. might be worth a check in the tech archive? Quote Link to comment Share on other sites More sharing options...
BogMonster Posted June 27, 2007 Share Posted June 27, 2007 Mount it on its side so that the inlet and outlet are in the right place for a tdi?Use a saab cooler and suffer the longer pipes? Lewis I think you will probably need to extend the bonnet upwards if you mount a Td5 intercooler on its side Quote Link to comment Share on other sites More sharing options...
Lars L Posted June 27, 2007 Share Posted June 27, 2007 Longer pipes don't seem to cause any problems if done wisely. I have put a 200Tdi from a Disco into my 110 and the donor had a big intercooler of unknown origin. It is of full width and with a pipe in each upper corner. I have run a pipe from the turbo (which sits on the LH side) to the RH side i/c inlet and have taken the shorter route into the intake manifold. After a run, the pipe from the turbo is a bit hot. I can touch it by hand so maybe 50-60°C, while the pipe into the engine is stone cold. In order to have the turbocharger a chance to do what it's supposed to, I've also connected the wastegate hose to a nipple in the intake instead of directly after the turbo outlet. Quote Link to comment Share on other sites More sharing options...
michael calvert Posted June 29, 2007 Share Posted June 29, 2007 I though about moving the rad to the middle and putiing the td% cooler acros infornt, but like you say the pipes are longer i was going to fit it towards the top of the rad so the pipe could be nearer the air intake on the block though stainless pipe and silicone hose should be ok instead of the rubber stuf Quote Link to comment Share on other sites More sharing options...
JST Posted June 30, 2007 Author Share Posted June 30, 2007 Just had a look at the setup and as Michael says it doesn't seem that hard to remove the tdi intercooler, then move the rad to the centre to allow the td5 intercooler to sit across the front of the rad (at the top) the inlet pipe then lines up almost perfectly, just needs an extension to connect to the existing top intercooler pipe. On the other side, i reckon you could use another top metal 200tdi def pipe, but laid horizontally to join up to the existing outlet pipework. expect i would need to move my rad back a fraction as well due to the winch etc. But is any of it worth it? Does anyone know the difference in air temp between inlet and outlet on td5 and tdi intercoolers? No point doing it if there is little/no gain. Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted July 1, 2007 Share Posted July 1, 2007 If you move the rad, will the oil cooler pipes reach without being modified, lengthening the hose and bending the pipework ? Does the 200 have an oil cooler, I'm sure it has Mo Quote Link to comment Share on other sites More sharing options...
JST Posted July 1, 2007 Author Share Posted July 1, 2007 Mo, yep i reckon there is more than enough slack in the oil cooler pipes to move it the required 2" across, plus enough flex in coolant pipes which can be shortened a little as well. Quote Link to comment Share on other sites More sharing options...
