Gromit Posted July 29, 2007 Share Posted July 29, 2007 It's time for new tyres. I'm currently running General SAGs radials, and I don't think much of them. In the wet, it goes sideways at roundabouts, locks up under braking, and is generally not much fun at all. Offroad, they are ok-ish, but they don't clear mud very well at all. So, I'm thinking of Generals AT2, and hoping to get some wolf rims, to increase the offset. So, what size should I get with a 2" lift? many thanks! Quote Link to comment Share on other sites More sharing options...
western Posted July 30, 2007 Share Posted July 30, 2007 either 265/75 or if available 255/85 radial construction & 16 inch to match the wheels. Quote Link to comment Share on other sites More sharing options...
q-rover Posted July 30, 2007 Share Posted July 30, 2007 Your standard size is either 235.85x16 or 265.75x16. These 2 sizes are very similar in diameter so if you add a 2" lift and don't get a larger diameter tyre then you will have a lot of empty space in the arches. I would suggest 255.85x16 or 285.75x16. Cooper tyres do a reasonable range of tread patterns in these sizes. If not then there is the BFG-MT. Quote Link to comment Share on other sites More sharing options...
Dunc Posted July 30, 2007 Share Posted July 30, 2007 I would suggest 255.85x16 or 285.75x16. Weehoo, they some big old boots. Thinking of a 110 with +2" running on 285/75s give me groinal warmth! Quote Link to comment Share on other sites More sharing options...
western Posted July 30, 2007 Share Posted July 30, 2007 255/85's are probably easier to obtain, got these in bfg mt's on my 110 Quote Link to comment Share on other sites More sharing options...
Gromit Posted July 31, 2007 Author Share Posted July 31, 2007 255/85's are probably easier to obtain, got these in bfg mt's on my 110 Thanks guys. Will see what my local supplier has, and if not will have to get them mail order I assume all will fit wolf rims? Ralph, you've them don't you? Also, should I be fitting tubes or not? Quote Link to comment Share on other sites More sharing options...
JST Posted July 31, 2007 Share Posted July 31, 2007 i am running 255/85s on wolf rims, no tubes, note some wolf rims are tubless some are tubed. 255 is the max you can go on a wolf rim, think the rim is 6.5J Quote Link to comment Share on other sites More sharing options...
western Posted July 31, 2007 Share Posted July 31, 2007 yes, gromit, got XD/Wolf's on my 110 tubeless tyres, run ok. Quote Link to comment Share on other sites More sharing options...
Gromit Posted July 31, 2007 Author Share Posted July 31, 2007 255 is the max you can go on a wolf rim, think the rim is 6.5J What does the 6.5J mean? And why can you not exceed 255 on a wolf? Quote Link to comment Share on other sites More sharing options...
western Posted July 31, 2007 Share Posted July 31, 2007 6.5 is the rim width, the J is IIRC the well profile, any wider the tyre will not seat correctly & you'll get a pinched in look, not good for the tyre or you. wheel technical & More Quote Link to comment Share on other sites More sharing options...
Gromit Posted July 31, 2007 Author Share Posted July 31, 2007 6.5 is the rim width, the J is IIRC the well profile, any wider the tyre will not seat correctly & you'll get a pinched in look, not good for the tyre or you. wheel technical & More Thanks Ralph. So, I guess the J determines if a tube can be fitted or not. Looking at wolf rims online, I only see one type, and it doesn´t mention tubed or not. I can get 3 s´hand locally, so will need to ensure the 4th is the same, where ever I get it from. Quote Link to comment Share on other sites More sharing options...
western Posted August 1, 2007 Share Posted August 1, 2007 the XD/Wolf rims have different part numbers for tube & tubeless type, mine are ANR5593 Tubed but I run MT's [no tubes] without any problems Quote Link to comment Share on other sites More sharing options...
LandyManLuke Posted August 1, 2007 Share Posted August 1, 2007 FWIW, 255/85R16 on modulars, have a better turning circle than on wolf rims due to the offset. I've used both on my 90 and noticed the difference. Quote Link to comment Share on other sites More sharing options...
western Posted August 1, 2007 Share Posted August 1, 2007 but I'm not keen on modular wheels, a mate has them on his old 110, just don't like the pretend split rim effect, Quote Link to comment Share on other sites More sharing options...
JST Posted August 1, 2007 Share Posted August 1, 2007 FWIW, 255/85R16 on modulars, have a better turning circle than on wolf rims due to the offset. I've used both on my 90 and noticed the difference. correct but dont forget Wolf rims are designed to curve in more (ie less off set) to provide protection for the caliper etc which is important in deep mud/bog. Quote Link to comment Share on other sites More sharing options...
cold_n_wet Posted August 5, 2007 Share Posted August 5, 2007 I put Cooper STT 285/75 R16 on Zu rims on my 2" lifted 110. I like the way it looked, I had 265/75 R16 on previously, but I thought it looked far too high under the wheel arches. Glen Quote Link to comment Share on other sites More sharing options...
Dunc Posted August 14, 2007 Share Posted August 14, 2007 Now that is one sexy truck. Quote Link to comment Share on other sites More sharing options...
Grant Posted August 14, 2007 Share Posted August 14, 2007 I like the 265/75 R16 with BFG MT's but I dont have mine lifted. The MT are a great tyre on and off road, Not too much road drone. Quote Link to comment Share on other sites More sharing options...
Gromit Posted August 14, 2007 Author Share Posted August 14, 2007 Cheers guys. Should be picking up the wolfs at the weekend and will then clean them up. 255/85s BFG MTs going on them Quote Link to comment Share on other sites More sharing options...
western Posted August 14, 2007 Share Posted August 14, 2007 good choice. Quote Link to comment Share on other sites More sharing options...
Dunc Posted August 15, 2007 Share Posted August 15, 2007 Cheers guys. Should be picking up the wolfs at the weekend and will then clean them up. 255/85s BFG MTs going on them Out of interest, how much do 255/85 tyres knock the speedo out? Quote Link to comment Share on other sites More sharing options...
Grant Posted August 15, 2007 Share Posted August 15, 2007 Good choice Im a real fan of BFG MT's Quote Link to comment Share on other sites More sharing options...
G_Cam Posted November 28, 2007 Share Posted November 28, 2007 I put Cooper STT 285/75 R16 on Zu rims on my 2" lifted 110.I like the way it looked, I had 265/75 R16 on previously, but I thought it looked far too high under the wheel arches. Glen Looks great - how does it handle now compared to having more 'standard' rubber on it? Quote Link to comment Share on other sites More sharing options...
nicks90 Posted November 29, 2007 Share Posted November 29, 2007 Out of interest, how much do 255/85 tyres knock the speedo out? they are a 33" tall tyre - as opposed to standard 235/85 and 265/75 fitment, which are approx 31.5"-32" tall. so about 5%. Quote Link to comment Share on other sites More sharing options...
tacr2man Posted November 29, 2007 Share Posted November 29, 2007 I like the 265/75 R16 with BFG MT's but I dont have mine lifted.The MT are a great tyre on and off road, Not too much road drone. Yours must be a diesel , but I agree about the on and off bit Quote Link to comment Share on other sites More sharing options...
