Lightning Posted September 11, 2007 Share Posted September 11, 2007 It does not say in the owner's manual that if you open the bonnet further than normal (towards vertical) say to top up the coolant....it falls out of the hinges, gets cought by the wind, and ends up on the floor after denting the wing! Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted September 11, 2007 Share Posted September 11, 2007 Indeed it doesn't. It can also disappear over the top of your landy at 70 mph if you forget to latch it. Doesn't say that in the manual either Also if you have it vertical and the wind blows it back down, don't try to catch it, it hurts afterwards The manual also failed to mention that. These manual authors lack foresight in my opinion. I have tried the above and can verify that they can occur Mo Quote Link to comment Share on other sites More sharing options...
BogMonster Posted September 11, 2007 Share Posted September 11, 2007 It's very convenient to be able to take the bonnet off, lets a lot more daylight in there too A common trick is to tilt it right back and take a bit of rope or strong twine from the bonnet latch back over the roof to the rear door spare wheel carrier to hold it up out of the way. A bit of tension on the string stops it from going flyabout but don't pull too hard. Quote Link to comment Share on other sites More sharing options...
Litch Posted September 11, 2007 Share Posted September 11, 2007 I understand the occasional need to lean the bonnet all the way back as I have done that many times in the past but that was for maintenance, repairs etc. Why would you need to do it to top up the coolant? Quote Link to comment Share on other sites More sharing options...
GBMUD Posted September 11, 2007 Share Posted September 11, 2007 Don't try this with an '07 - as my friend Dave did with a demonstrator! The bulge hits the wipers and then modifies itself to make space resulting un some unsightly dents. Chris Quote Link to comment Share on other sites More sharing options...
sheeppimp Posted September 11, 2007 Share Posted September 11, 2007 Don't try this with an '07 - as my friend Dave did with a demonstrator! The bulge hits the wipers and then modifies itself to make space resulting un some unsightly dents.Chris best to find these things out on a demonstrator tho or with a bonnet spare wheel mounting on it, i did - gust of wind and no more windscreen (and a little embarassing) Quote Link to comment Share on other sites More sharing options...
Gromit Posted September 12, 2007 Share Posted September 12, 2007 A common trick is to tilt it right back and take a bit of rope or strong twine Don't forget to close the bulkhead vents. Quote Link to comment Share on other sites More sharing options...
Lightning Posted September 12, 2007 Author Share Posted September 12, 2007 I could have topped up the coolant without opening it further but thought it would be easier...I had seen one at the dealer with the bonnet right up and leaning on the windscreen. I agree that it is a good feature once you know about it. Will make servicing easier. Just need to make sure it's tied back as somebody suggested. Quote Link to comment Share on other sites More sharing options...
sean f Posted September 12, 2007 Share Posted September 12, 2007 If you do lean the bonnet all the way back remeber to tie it back. I didn't once and it resulted in a trip to the dentist to have my front teeth rebuilt when the wind blew it done on the back of my head, suffice it ti say it hurt !!. Quote Link to comment Share on other sites More sharing options...
Dave K Posted September 13, 2007 Share Posted September 13, 2007 Make sure you use a rope! Bungee cords can sometimes stretch at the wrong moment, & yes, it does hurt as the bonnet smacks the back of your head. Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted September 13, 2007 Share Posted September 13, 2007 Another thing that stupid manual doesn't say, is if you're about to remove the bonnet totally, don't open it up and use the proper "bonnet upright stand" thingy then proceed to remove the split pin and washer (that hold the aforementioned bonnet upright stand thingy) and pull it off, cos it will then immediately stop doing its job and the bonnet will smack you in the back of your head. don't ask.... Quote Link to comment Share on other sites More sharing options...
Gromit Posted September 13, 2007 Share Posted September 13, 2007 While we are detailing the manuals shortcomings; While standing on the wing, after lowering the bonnet from the vertical position, make sure your toes are out of the way before dropping the bonnet. Thankfully LR panel gaps are such that your toes are mildly crushed rather than removed completely. Quote Link to comment Share on other sites More sharing options...
