twizzle Posted September 26, 2007 Share Posted September 26, 2007 As im fitting the tdi in the 109 i have heared that the turbo is to close to chassie what happens if i lift the engine up about half inch to an inch on the engine mounts will it make any diffrence TWIZZLE Quote Link to comment Share on other sites More sharing options...
Jon White Posted September 26, 2007 Share Posted September 26, 2007 Probably not enough! Basically a disovery 200tdi manifold will not fit a 109. You'll need to find defender manifolds, or do some modifying! Jon Quote Link to comment Share on other sites More sharing options...
selectcase Posted October 2, 2007 Share Posted October 2, 2007 Sorry but i thought you were allready aware of this problem fron your previous thread 200 tdi in to straight six chassis if you lift the engine up you wil need to modify the bulkhead - your best bet is a set of defender 200tdi inlet manifolds and modify the alternator - there is a very detailed thread on fitting a 200tdi in to a 109 on the series 2 club forum pinned in the mechanical matters section where three or four of us were all contributing our experiences of this conversion. You could even use the 2.5td inlet, turbo and exhaust, i saw that on this forum somewhere in the past six months cheers will Quote Link to comment Share on other sites More sharing options...
twizzle Posted October 21, 2007 Author Share Posted October 21, 2007 Sorry but i thought you were allready aware of this problem fron your previous thread200 tdi in to straight six chassis if you lift the engine up you wil need to modify the bulkhead - your best bet is a set of defender 200tdi inlet manifolds and modify the alternator - there is a very detailed thread on fitting a 200tdi in to a 109 on the series 2 club forum pinned in the mechanical matters section where three or four of us were all contributing our experiences of this conversion. You could even use the 2.5td inlet, turbo and exhaust, i saw that on this forum somewhere in the past six months cheers will Just to proove you wrong a disco 200 tdi dose fit in a 109 Quote Link to comment Share on other sites More sharing options...
selectcase Posted October 21, 2007 Share Posted October 21, 2007 Just to proove you wrong a disco 200 tdi dose fit in a 109 Well done - what did you do? raise the engine and fabricate mounts? as that looks like loads of clearance now Quote Link to comment Share on other sites More sharing options...
sheeppimp Posted October 21, 2007 Share Posted October 21, 2007 Bit of explanation here: making it fit Quote Link to comment Share on other sites More sharing options...
twizzle Posted October 22, 2007 Author Share Posted October 22, 2007 Well done - what did you do? raise the engine and fabricate mounts? as that looks like loads of clearance now I fabricated the drivers side engine mount off a 90 engine sits very low TWIZZLE Quote Link to comment Share on other sites More sharing options...
LR90 Posted October 22, 2007 Share Posted October 22, 2007 Well have to admit I'm relieved to see you've found a way round this. I never thought for a moment there was trouble fitting the Disco lumb in a series. And reading the other thread, congrats on what looks like a very neat solution Quote Link to comment Share on other sites More sharing options...
twizzle Posted October 22, 2007 Author Share Posted October 22, 2007 Well have to admit I'm relieved to see you've found a way round this. I never thought for a moment there was trouble fitting the Disco lumb in a series. And reading the other thread, congrats on what looks like a very neat solution well thanks Trev. Quote Link to comment Share on other sites More sharing options...
twizzle Posted October 29, 2007 Author Share Posted October 29, 2007 well thanks Trev. some more photos Quote Link to comment Share on other sites More sharing options...
twizzle Posted October 29, 2007 Author Share Posted October 29, 2007 an more Quote Link to comment Share on other sites More sharing options...
Les Henson Posted October 31, 2007 Share Posted October 31, 2007 Your PAS box is the wrong way up. Les. Quote Link to comment Share on other sites More sharing options...
twizzle Posted November 2, 2007 Author Share Posted November 2, 2007 Your PAS box is the wrong way up. Les. dam hadnt realised that good job we havent fitted it then thanks for noticeing Les Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 5, 2007 Share Posted November 5, 2007 Lovely job on the fitting/engine mounts - looks very good. Les. Quote Link to comment Share on other sites More sharing options...
twizzle Posted November 11, 2007 Author Share Posted November 11, 2007 Lovely job on the fitting/engine mounts - looks very good.Les. there we are Les just for you TWIZZLE Quote Link to comment Share on other sites More sharing options...
Tonk Posted November 12, 2007 Share Posted November 12, 2007 twizzlw, take the rubber boots off your shocks, they trap mud under them, Quote Link to comment Share on other sites More sharing options...
twizzle Posted November 13, 2007 Author Share Posted November 13, 2007 twizzlw,take the rubber boots off your shocks, they trap mud under them, will do Tonk THANKS TWIZZLE Quote Link to comment Share on other sites More sharing options...
