McS Posted November 2, 2005 Share Posted November 2, 2005 Just wondering if, since I'm using red LED's anyway, I can make the stop/tail and rear fog cover clear or whether the Man from the Ministry will have something to say about it.... Cheers, McS Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 2, 2005 Share Posted November 2, 2005 Emitted light must be red, how you do that is entirely up to you actually. Red lenses, red bulbs, red led's make no diference as long as it is red. A lot of cars have orange indicator bulbs rather than lenses. Les. Quote Link to comment Share on other sites More sharing options...
Jon White Posted November 2, 2005 Share Posted November 2, 2005 I beleive technically the lens should also be E marked......... Jon Quote Link to comment Share on other sites More sharing options...
McS Posted November 2, 2005 Author Share Posted November 2, 2005 Cheers for the replies guys. I've had clear indicators for ages now, just finally dawned on me that I could do the red ones too! E-marking wont be an issue as I'll be using NAS lenses. Cheers, McS Quote Link to comment Share on other sites More sharing options...
Mean Green Posted November 3, 2005 Share Posted November 3, 2005 I have had clear stop/tail lenses with LED's for a couple of years now and MR MOT has never had anything to say about them. I am currently thinking about changing the Fog too, but have not yet worked out how to do it with LED's as the standard bulb mounts side on and LED's aint to great at that. Quote Link to comment Share on other sites More sharing options...
Neil Marshall Posted November 3, 2005 Share Posted November 3, 2005 The MOT Test Manual simply requires that rear lamps are not broken or show any white light. [From the Manual] The MOT Tester is required to do the following: 1. Check that two front and two rear position lamps are fitted to the vehicle, one of each oh each side. 2. Check the presence, condition, security and operation of the switch. 3. Check that the front and rear position lamps show light of the correct colour. Reasons for failure are: 1. An obligatory lamp missing. 2. A switch missing, faulty, insecure, or not able to be operated from the normal driving position. 3. a. A front position lamp shows a light other than white to the front, (or yellow if incorporated in a yellow headlamp): or b. A rear position lamp shows a light other than red to the rear. So red LED bulbs with clear lenses are absolutely fine - hope this helps Neil Quote Link to comment Share on other sites More sharing options...
gelf Posted November 3, 2005 Share Posted November 3, 2005 so as ive got military lenses on mine it would be quite simple................ so would simonb have these red and orange LED's? Quote Link to comment Share on other sites More sharing options...
Les Henson Posted November 3, 2005 Share Posted November 3, 2005 LED's are getting more and more popular, as well as getting cheaper. Most LR parts places sell them as well as the more usual motor factors. Les. Quote Link to comment Share on other sites More sharing options...
simonb Posted November 3, 2005 Share Posted November 3, 2005 Don't have leds for sale for side/stop. Indicators will need a load resistor to get correct flash rate. Do a search on Eblag for these leds. Note also that LR wire the lamp holders up with the cap + and the pip - on side and indicators, so u will need to cut the wires at the holder and swap over. Quote Link to comment Share on other sites More sharing options...
freeagent Posted November 7, 2005 Share Posted November 7, 2005 got mine from 'ultraleds.com' only £4.99 and they are realy good... Quote Link to comment Share on other sites More sharing options...
