TheBeastie Posted October 19, 2007 Share Posted October 19, 2007 I am wanting to lift The Beastie up on all four corners so I can work underneath a bit more easily. I now have two pairs of axle stands and envisaged lifting front on jack and supporting on axle stands; then doing the same at the back. My question is whether or not this is a good approach and if there is likely to be any unexpected effects when lifting the back axle. Presumably once it is up on the four stands I am OK unless something big hits it and topples it in which case I have a bit of a problem . I am sure it is a fairly standard procedure but thought I would ask just in case there are some traps for the unwary. Thanks Malcy Quote Link to comment Share on other sites More sharing options...
western Posted October 19, 2007 Share Posted October 19, 2007 sounds good to me, just lift one corner at a time until all 4 tyres are off the ground, just don't go to high on the stand tubes Quote Link to comment Share on other sites More sharing options...
mike4444244 Posted October 19, 2007 Share Posted October 19, 2007 its fine as long as you remember that it dosent take much of a shove to tip them off! Quote Link to comment Share on other sites More sharing options...
Guest diesel_jim Posted October 19, 2007 Share Posted October 19, 2007 A mate of mine bought 4 ex military stands at sodbury last time... they're about 2' tall, non adjustable, but ideal for LR height chassis. he's currently got his 90 axle-less up on them, and, not that you'd want to, but you could work under it as there is plenty of room. as said, carefull though as a good nudge would see a big pile of mess on the floor. Quote Link to comment Share on other sites More sharing options...
Lewis Posted October 19, 2007 Share Posted October 19, 2007 Something i do is when i have the vehicle on the stands I like give it a good shake and push; I'd rather it fell off at this point if its going to, rather than when I'm underneath it with a 9" Grinder in hand Quote Link to comment Share on other sites More sharing options...
Turbocharger Posted October 20, 2007 Share Posted October 20, 2007 As was said, give it a bl**dy good shove before you go under it (ideally before you take the wheels off). When I'm in scrapyards where cars are piled up I've always tried to tip the top car off before I get in it - it's horrible when it moves... Quote Link to comment Share on other sites More sharing options...
bobtail4x4 Posted October 20, 2007 Share Posted October 20, 2007 wheel ramps are safer? Quote Link to comment Share on other sites More sharing options...
Raggylad Posted October 20, 2007 Share Posted October 20, 2007 I use wheel ramps at one end & axle stands at the other if I need to get all 4 corners up. Much safer ! Quote Link to comment Share on other sites More sharing options...
Litch Posted October 21, 2007 Share Posted October 21, 2007 As long as axle stands are correctly rated and positioned then you shouldn't have any problems at all and the vehicle should be rock solid. I had my 101 like this for months while I was rebuilding it and there was no movement whatsoever. I still do it occasionally when servicing my 90 as it saves having to jack up each axle at a time. If however the stands are not positioned correctly (check all three feet are on the ground when they take the load as they can lift a foot in some situations) then yes you will have problems but that is down to you when you set it up. Yes ramps are very good as long as you want to leave the wheels in position and I occasionally use a set but if you want the wheels out of the way then they are no good at all. Quote Link to comment Share on other sites More sharing options...
white90 Posted October 21, 2007 Share Posted October 21, 2007 whe ever I get under the car I always put wheels/tyres underneath first or blocks of wood(old railway sleeper cut offs) that way if the worst happens it would be a brown trouser moment but not a squashed trouser moment Quote Link to comment Share on other sites More sharing options...
gsr341 Posted October 21, 2007 Share Posted October 21, 2007 i use 4 axel stands (rated at 6tonnes each ) as long as correctly positioned they are very safe , ive no problems working on a vehicle on axel stands , much much safer that a hydralic jack Quote Link to comment Share on other sites More sharing options...
white90 Posted October 21, 2007 Share Posted October 21, 2007 Worked in a Fire engine garage once they had the engines on stands 4-5ft in the air quite a sight I must say Quote Link to comment Share on other sites More sharing options...
Dave78 Posted October 22, 2007 Share Posted October 22, 2007 I've had my old SIII LWB on four axle stands before. Would agree with all the advice already given. I used to jack up and then support each corner in turn. Once you have more than one corner up on axle stands, it's a good idea to re-check all stands. I used to find that on jacking up the rear of the vehicle (with the front already on stands) the front stands did move alittle. And yep, once all up leave the wheels on and give it a good shove - as said better it falls off at that point that with you under it. Quote Link to comment Share on other sites More sharing options...
freeagent Posted October 22, 2007 Share Posted October 22, 2007 I'd agree with White90, put the wheels underneath it somewhere when you have taken them off, and put a few off cuts of timber etc under it.... you just want something other than yourself to break its fall if it topples off the axle stands... Quote Link to comment Share on other sites More sharing options...
