Hybrid_From_Hell Posted November 27, 2007 Share Posted November 27, 2007 I have just been offerred an upright (6ft) Hydraulic press - a biggee at 50 Tons ! Not too expensive so am think re having it as it takes up only a small floor space. So, the Q is I have been thinking of getting a 3 4 5 flypress, for forming punching etc, I also sometimes have to go a 2 hr round trip to use a mates Folding press, and I was therefore thinking For bending up small bits of plate and punching holes through, with the right tooling and a few mods how does the panel think this 50T press would compare with flypress or BIG monster hyd press doing smaller (say 1 foot 6mm thick 90 degree bend etc) ?? Thoughts ? nige Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 27, 2007 Share Posted November 27, 2007 Have it - or sell it to me After using Jez's press it's gone up my workshop wishlist massively, such a handy tool for bending/pressing/punching/straightening. Quote Link to comment Share on other sites More sharing options...
Ozyboy Posted November 27, 2007 Share Posted November 27, 2007 Mmmm, Thoughts FWIW. I have a 50 ton press, and they are hugely useful (last nights job straightening the nose on a farm elevator, then weld in some additional strength). For folding, i think you'll get frustrated by the lack of speed . I do with mine, maybe as its a 6 inch wide piston, and take a good few hand pumps to get the thing moving. Some of the more modern stuff with a smaller ram, may be easier (read less time consuming to operate) Flypress, same reason as above, pretty slow compared to a dedicated flypress. BTW, for folding, i made a (just liftable into the vice) folder that will take 1M wide sheet. Will fold upto 4mm steel. Copied the machine mart stuff and beef'd it up a bit. Sits under the bench when not in use. I'd get the press, build a folder, and see how you go before investing in a flypress. Just my thoughts. Oz Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 27, 2007 Share Posted November 27, 2007 Hand crank? Yuk - I'd track down a hydro power pack, for example from a Transit tipper, and use that. Quote Link to comment Share on other sites More sharing options...
Ozyboy Posted November 27, 2007 Share Posted November 27, 2007 Hand crank? Yuk - I'd track down a hydro power pack, for example from a Transit tipper, and use that. Great idea. Its just one of those Round Tuit jobs.... Only use the press maybe one a month, and therefore not justified the time YET, to modify i guess. although your suggestion has got me thinking..... Maybe a hydralic anti ram barrier in front of the garage door. like one of those multi story plastic jobbies, but with a ram i could use a piece of 6 inch square tube..... Mmmmm Sorry getting OT now. Oz Quote Link to comment Share on other sites More sharing options...
Mo Murphy Posted November 28, 2007 Share Posted November 28, 2007 Flypresses are OK for thin stuff, say up to 18 swg but no good for what you need Nige. Mo Quote Link to comment Share on other sites More sharing options...
bishbosh Posted November 28, 2007 Share Posted November 28, 2007 Flypresses are OK for thin stuff, say up to 18 swg but no good for what you need Nige.Mo Quote Link to comment Share on other sites More sharing options...
dollythelw Posted November 29, 2007 Share Posted November 29, 2007 two cheap ideas The bush-o-matic, handy for lending out and doing bushes, bearings.. little stuff (£ Sweet FA) The "Day job" (soul crushing, relentless and unavoidably necessary) press, all up cost £80 built out of scrap Quote Link to comment Share on other sites More sharing options...
FridgeFreezer Posted November 29, 2007 Share Posted November 29, 2007 That reminds me, I still have the bush-o-matic better give that back at some point! Damn handy little thing though. Quote Link to comment Share on other sites More sharing options...
simonr Posted December 2, 2007 Share Posted December 2, 2007 I have a fly press. It's only a No 4 - but it's brilliant! What have I used it for recently? Folding 12mm plate, forming 6 x 100 bar, changing bushes & UJ's OK, you can do all these things with a hydraulic press, but because you can use the energy stored in the momentum of the fly-weights to generate an impulse force (impact), a relatively small flypress can out-perform even pretty big hydraulics. With the stroke adjustment collar - it gives fantastic repeatability when forming. When I made my cage, the plates used to bolt-through-the-bodywork were made from 6mm plate formed on a specially constructed die. When they were stacked on top of one another, all 12 were exactly the same shape & curvature. It's fast too - if that's a consideration. Si Quote Link to comment Share on other sites More sharing options...
