hattymender Posted February 13, 2008 Share Posted February 13, 2008 The 'stately' progress you can make with a 2.5 Petrol pulling a 110 is beginning to pale. It's taken 3 years and 40k miles but I'm starting to take the hint. I was thinking of a V8 with all the agro of exhausts & gear box but while mooching 'round a local scrap yard today (as you do) I noticed a 90 in the corner with a Discovery 200tdi. An unfinished project belonging to the yard owner apparently. Looks as it he's bolted it to the gear box but not much more. He may be willing to sell the engine. Mmmm....temptation. I've done a search and found lots of advice on converting older diesels to TDi but not much on petrols. Looks as if engine mounts and gear box should be ok with a few mods. Radiator/intercooler a bit higher but can be sorted with a bit of cutting/welding. But I've still got some worries: Fuel system. Diesel filter in lieu of petrol one but what about the tank pump? Ok with diesel? Exhaust. Know I need to make a new down pipe from turbo but can you use a petrol exhaust? It's quite new. And I'm tight. So I'd like to keep it. Wiring. Glow plugs & all that. Petrol ignition switch ok? Glow plug relay needed? What's compatible? I've already got a 2.5D (non turbo) alternator but will it and the steering pump transfer? (May be that they're ok on the donor but keeping a spare doesn't hurt). Cheers Rich PS. Any good advice on getting another big spend past wife without agro much appreciated.......... Quote Link to comment Share on other sites More sharing options...
honitonhobbit Posted February 13, 2008 Share Posted February 13, 2008 Petrol is the Devils Fuel and you WILL go to hell for using it Quote Link to comment Share on other sites More sharing options...
orangutan Posted February 13, 2008 Share Posted February 13, 2008 The 'stately' progress you can make with a 2.5 Petrol pulling a 110 is beginning to pale. It's taken 3 years and 40k miles but I'm starting to take the hint.I was thinking of a V8 with all the agro of exhausts & gear box but while mooching 'round a local scrap yard today (as you do) I noticed a 90 in the corner with a Discovery 200tdi. An unfinished project belonging to the yard owner apparently. Looks as it he's bolted it to the gear box but not much more. He may be willing to sell the engine. Mmmm....temptation. I've done a search and found lots of advice on converting older diesels to TDi but not much on petrols. Looks as if engine mounts and gear box should be ok with a few mods. Radiator/intercooler a bit higher but can be sorted with a bit of cutting/welding. But I've still got some worries: Fuel system. Diesel filter in lieu of petrol one but what about the tank pump? Ok with diesel? Exhaust. Know I need to make a new down pipe from turbo but can you use a petrol exhaust? It's quite new. And I'm tight. So I'd like to keep it. Wiring. Glow plugs & all that. Petrol ignition switch ok? Glow plug relay needed? What's compatible? I've already got a 2.5D (non turbo) alternator but will it and the steering pump transfer? (May be that they're ok on the donor but keeping a spare doesn't hurt). Cheers Rich PS. Any good advice on getting another big spend past wife without agro much appreciated.......... Hehe - the progress of a diesel is also "stately" compared to a V8...... Having driven both today I resolved to stay with the V8 - the power, torque and sound just does it for me...and surely they are cheaper to maintain in the long run - more simple? Good luck, whatever case you put to your other half will find you in severe brownie-point debt at the very least and in the divorce court at the worst. Quote Link to comment Share on other sites More sharing options...
hattymender Posted February 13, 2008 Author Share Posted February 13, 2008 Petrol is the Devils Fuel and you WILL go to hell for using it Petrol? Yes, I may have said it but it's not seen petrol in months. LPG. Helps the wallet. Doesn't make it any faster though. Quote Link to comment Share on other sites More sharing options...
nicks90 Posted February 14, 2008 Share Posted February 14, 2008 if you already have lpg installed, then seems daft not to go v8 - cos the fuel costs will be about the same as a diesel and all your electrics/fuel lines are already pretty much in place. (did i really just say that ? ) Quote Link to comment Share on other sites More sharing options...
need4speed Posted February 14, 2008 Share Posted February 14, 2008 'Stately' and 'Diesel'...Now theres two terms that belong together.. Quote Link to comment Share on other sites More sharing options...
discojmz Posted February 14, 2008 Share Posted February 14, 2008 Having driven both today I resolved to stay with the V8 - the power, torque and sound just does it for me...and surely they are cheaper to maintain in the long run - more simple? err... squash bang squash bang none of that horrible electrical stuff for starters. how you can argue a v8 is cheaper to maintain OR simpler is beyond me for one thing i reckon 'proper' rebuild cost of a v8 has to be loads more because of the sheer number of extra parts and extra cylinders, then there's the V8's very finite lifespan in comparison and they just dont love the water like a tdi it's not even worth me bothering to defend the tdi's performance, it depends what you want out of your vehicle. but personally i would have my 200tdi over a 300tdi and the 300tdi over a v8 when it's my main vehicle. if it were a toy.... i could be swayed i think, but i like the water and i dont like computers running my car. Quote Link to comment Share on other sites More sharing options...
Venturers SAR Posted February 14, 2008 Share Posted February 14, 2008 As a Rescue Service working in floods , we have just swapped our V8 to a 300TDI , suffering withdrawal symptoms from the lack of grunt and top speed. To be honest with a lemonade bottle on top of the coil , a shield in front of the distributor , use of silicon grease , and cling film . Never had a flood rescue problem , where Diesel Cars sucked water into engine with terminal damage. To be honest do not think we ever want t wade deep enough to turn our headlights into gold fish bowls A V8 may be a little more thirsty ; but if you enjoy the burble of the exhaust ,and brute power and a engine which goes on for ever . ENJOY Quote Link to comment Share on other sites More sharing options...
muzaz Posted February 14, 2008 Share Posted February 14, 2008 Never had a flood rescue problem , where Diesel Carssucked water into engine with terminal damage. SURELY Quote Link to comment Share on other sites More sharing options...
muzaz Posted February 14, 2008 Share Posted February 14, 2008 Never had a flood rescue problem , where Diesel Carssucked water into engine with terminal damage. Surely its not the engine's fault, if you venture too deep to get the engine to suck water you should fit a snorkel no? Else youre a ver very bad man! Quote Link to comment Share on other sites More sharing options...
hattymender Posted February 14, 2008 Author Share Posted February 14, 2008 Oh, great help you lot. I was positive a diesel was the way to go. Now it's a V8 again. Or not. Maybe. I dunno. Should have known better than to go anywhere near the petrol vs diesel subject Think I'll decide using the usual scientific method. I'll buy the first that comes along within my budget. Then somebody will tell me that I could have got a better cheaper deal etc. Then I'll sulk............... Quote Link to comment Share on other sites More sharing options...
bishbosh Posted February 14, 2008 Share Posted February 14, 2008 Looks like a perfect plan! If you want my 2p - I had a V8 and went to diseasel purely on the grounds of economy as the car became a daily driver. If it was still a toy it would still be V8 no contest. The TDi gets 24-27mpg being auto so would compare similarly with a gassed V8 on running costs. V8 gas and megasquirt is the way to go I reckon. Quote Link to comment Share on other sites More sharing options...
